Yes it seems it's cpu related after those some tests by jmax and you.
Can you confirm the same limit (263 FSB) with a lower multi ?
Hotbug , lol, it's funny :D
its still cant be said ;) mikeguava tested much cpu's on same board and all hit same wall.. they are step 4 and step 8 .. es and retail.
I only gained 4mhz on -190... so :(
lower multi's same fsb wall ;) with all cpu's
I did on 12xQuote:
Originally Posted by misteroadster
263 = instant freeze...
maybe easypanic will bring his T2600ES (about the same as mine) next week, we will test it and if it hits the same wall as on his mobo, we know what it is :)
probably some guys had bugged aopen too ...
Ok, confirmed :toast:Quote:
Originally Posted by Gamer
i will test ln2 @ 0C tommarow.. if no gain were in :banana::banana::banana::banana: ;) coz i still think its not the cpu.
i have the same, 262 stable (Pi), 263 freeze!Quote:
tomorrow i get my T2600 QKHK step. 8
yes, Maybe your bottleneck is your m/b, maybe bugged :(Quote:
Originally Posted by Waus-mod
just wait on hipro ;)Quote:
Well, booted the autocascade just now.....and wouldn't ya know it??? The YONAH HAS A COLD BUG!! These things put out almost no heat load and I booted @ -70C evap and tried to push the FSB and barely made it to 3G before locking up. I just thought it was a fluke so I re-booted and ran 32m to see if my system was unstable. Finished a few iterations and then while the bench was running, I started up clockgen. In the meantime, my evap temps CONTINUED TO DROP :eek: (while running 32m). I started pushing the fsb again - now the evap was reporting -75C - and locked up when I hit 2.9G. Restarted once again and ran another 32m and repeated what I did in the prior boot. This time, I locked up after I clockgenned to 2.75G - evap temps @ -80C. Looks like an issue with FSB limitations as temps get lower. Maybe that's why Waus was only able to go 4mhz @ -190C.......
Hey Stephen have you tried booting with 240+ fsb yet ;)
Booting? Or just running @ 240+ FSB? Cuz the cpu has run 1m @ 241FSB on air...look back a few posts ;)Quote:
Originally Posted by G H Z
Aopen support Merom
http://homepage19.seed.net.tw/web@3/youch/photo/001.jpg
OMG Andre, how did you get Merom to work? I know of a couple of people who've tried it on the Aopen and it didn't work....Quote:
Originally Posted by AndreYang
Originally Posted by s7e9h3n
not me.....................
The pic come from Taiwan friend........I try to ask to him and share the bios.
Thanks man :toast:Quote:
that's great news....that it's only bios and not a more serious mod:toast:Quote:
what is the real speed of that memron andre?
So whats up with the coldbug? Is anyone else having this problem on extreme cold? teamjapan, were you guys having any of these problems if so how did you get past it?
13x166 2,16 see Cpu-z SpeciQuote:
Originally Posted by metro.cl
Hey kid that's what kyosens TCore mod is all about, look back a couple of pages.
Stephen I mean booting, it seems that's common among the top Yonah guys ;) I got my boards today, R570 is a small one, good job on the mod.
So you're saying that if I BOOT @ 240+FSB, I'll be able to push the cpu even further? If so, I'll try that first thing tomorrow.Quote:
On a side note, yep, that r570 is a tiny one. I had issues booting into windows at first, but finally realized that a solder point had come loose on the resistor. Fixed it and could then boot into windows. Funny thing is, whenever I try to access the bios on the board, I get a blue line on the bottom with a cursor on the top left of the screen. Looks as if the board still may be "partially" bugging or I've corrupted [another] bios :rolleyes: :p:
My wild guess...Quote:
1st. shipment batch to Newegg...need kyosen's mod for cold boot @ negative temp...
http://img92.imageshack.us/img92/9775/1b0dg.jpg
1st. shipment batch to Japan's retail channel....Probly ok with negative temp. boot...
http://img92.imageshack.us/img92/5551/1a1rn.jpg
Cold bug with Yonah is a different story...Still wondering if it can boot @<90C evap. temp...
If i have 0 C i can't get in bios..i have to wait till the temps goes >0
