bought 3 whats? p4p800se?Quote:
Originally Posted by alexio
:EDIT: nm guess you mean dothans.. yeah you are sick :D lol
3 Dothans yes :banana:
But I'm having problems with the 1009003 bios. Normally I flash in windows because I don't have a working floppydrive right now. The asus update thingy keeps telling me that the date in the bios is later than the current one :confused: and that I have to flash from DOS. I don't know what this exactly means but I changed the date in windows a few times, I'm not sure if this is what they really mean.
Does someone have an idea? It flashes the 004 bios just fine.
basically the windows version will not let u flash to an older bios.
u would have to boot from a floppy disk into dos,
Alternativ ... maybe a bootable image of cd,
not sure if that will work tho.
I'll do some hexediting then. Changing the bios version with a hexeditor shouldn't be too hard. I'll try winflash first.
http://img.photobucket.com/albums/v3...3/P1060004.jpg
Do you like my foot?
One of them has been opened and there is a chance it's dead, I got it for free :woot:
oh YES IT LETS you do that! you just need to check the option to allow it in preferences or options or whatever the section of it is there :)Quote:
Originally Posted by ibby
Thank you, I'll take a look at it.Quote:
Originally Posted by bcn
The cpu I mentioned above works btw. I'm not going to tell you the price because I still need to sell 4 of 'em.
omg what kind of deal did you get on those? I assume you bought them all together........Quote:
1 is just from a normal store, 206 euro plus shipping. The price on the other 4 was better, I actually only paid for 3 and the 4th I got 4 free because the box was opened. I'm still hitting a wall at 2,6-2,7ghz though. I guess it is not too bad. Well I have 3 more cpu's to test, hope I can find one that does 2.8ghz+
:woot:Quote:
maybe i didnt look hard enough :slapass: :nono: :slap:
Am I luck?
750 2720mhz @ 1.36v air cooled and 247 fsb 2-2-2-5 @ 3.3v
http://img339.imageshack.us/img339/9...segs8zq.th.jpg
http://img339.imageshack.us/img339/7...27209na.th.jpg
http://service.futuremark.com/compare?2k1=8671254
Yes, You Have Luck!
Strange,Quote:
Originally Posted by PcCI2iminal
PM733 is an ULV 1.1 Ghz :confused:
Really good one :clap:
hey how much did it cost you that 733? :)
Wow my second Dothan loves high fsb's, it just needed an hour of burning in. With this thing I can boot into windows at 235mhz fsb and can set it to minimum 260mhz in windows, I have to test if it can do higher. Very odd that it now can boot at 235mhz fsb while it couldn't do that with my first Dothan :confused:
My first Dothan could do 245mhz fsb in windows :confused:
hey guys Cpuz's screen was bugged take a look of 01's screen and u c the rite 750
I have to say that it's a very good result. The Dothans I've tested both crapped out at about 2.6ghz. I still have 3 more to go :slobber:Quote:
Do you also have the "problem" that a certain speed is prime stable and only 1 or 2mhz higher fsb crashes the system in a second? With crashing I mean rebooting or freezing.
if i hit the 250 my sistem go to crash 4 sure and i go to windows all the time running with 190x14
i´ll try some prime with 2700 @ 1.36v
and good luck with yours Dothans
hey has anyone then tried LV and ULV dothans? would they works in a board? i mean they would get higher voltage which is better :) but would they boot and all?
I heard the system doesn't boot :(
That seems to be the typical behavior of DothansQuote:
I've got the same thing with the two one i had
:( From Asus Q&A :Quote:
5. Does CT-479 support Intel Pentium M "Low" & "Ultra Low" CPU ?
No, currently It DOES NOT support Intel Pentium M "Low"& "Ultra Low" CPU.
Maybe in a next bios , but does not seems to me that Asus is putting some efford to release a new bios for Dothans . :rolleyes:
Ok cool ;)
I'm now running prime at 9*280mhz, no mods (yet), not bad at all :)
Really nice :toast: .Quote:
What Vcore are you using ? Is it a 730 ?
It's a 740, I have 5 of them, this is the second one I test. This is without thermal paste so the temp will drop a little maybe increasing overclocking when I use paste.
Vcore is 1.35v real. Max I can do is about 2600mhz on this vcore and I don't think anything more really helps.
I somehow have a feeling that this cpu's like burning in. Atleast I somehow broke the maximum fsb lock after a while. Now lets see if my Dothan and chipset like 300+ fsb.
