heres my i7 950 under a vapochill 250watt version. only tried 1024 as the evaporator head temps went to high with anything over 1024. But it was BC2 stable for a 12 hour session.
You referring to me or Grinchy? If you're referring to Grinchy there's no need to drop back into derisive statements, and if you are referring to my post, you obviously haven't read the thread, or cannot understand my post. Either way, some things are best kept to yourself ;)
Sorry if my "Soap box" reference wasn't clear................And I wasn't being derisory.
Just thought that Grinchy wasn't for listening to the fact that this thread is for getting past 20 LinX with stability not having the most stable comp. Hence my referring to his "Soap box".
Sorry for any offence.:)
More thought needed next time (by me :up:)
None taken, I just think Grinchy has been given enough of a tongue lashing and to me it seemed that there was a simple language based misunderstanding causing the whole thing to start and continue.
Well no, we are onto it when something isn't in line with what it should be. Whether or not Zalbard will still include the scores is his choice, personally I'd ask for a re-run.
Don't know why you're quoting me? I am certainly no expert and do not have any say in this thread. I just posted my 980X results like anybody else. The fact that my gflops were low was not through any "detuning" as I had no idea how to. My results were what they were. More Knowledgeable ppl were happy that I had got the best figures I could.
My SB results are a lot higher (different architecture, better MCH possibly) but I did not influence my results with any special knowledge (even of Photoshop). I just assembled my box with watercooling and tried various bios and ram alterations and configurations (including a good PSU) to get as high a score as I could.
All this was, and is, for fun and only for fun.
If you have any grievances perhaps you should direct them to "Zalbard".
Apologies to you Zalbard if I'm "name dropping".
Finally got my MIVE on Thursday and finished putting everything together this morning. Here is my first shot at 5Ghz with 1.43vcore BIOS, 100% LLC.
i7 2600k L042B243 5000Mhz 1.435vcore LLC100% 4C8T
Maximus IV Extreme BIOS 1204
Watercooled
http://i580.photobucket.com/albums/s..._898-24-1T.jpg
SlaveOnDope - i3 530 [2C 4T] @ 4501.5mhz - 1.36v - Asus P7P55 WS - Air - 3015B118
slaveondope i believe your linx must still be running when you take the screenshot. and it might have to be on the 21st lop also
:wave:
I2600K @ 5000mhz - 1.48v - Asus P8P67 EVO - WATER - L039B461
111.5 GFLops PEAK .
http://img830.imageshack.us/img830/4...bilit2600k.jpg
Can I join? This is after owning an i7-965 and struggled to get 4 GHz on air.
xarot - i7 990X [6C 6T] @ 4500.4 MHz - 1.368 V - Asus P6T6 WS Revolution - AIR - ES
CPU: i7-2500K [#L048] @ 5100.1Mhz
Cooler : Mega Halem & Fan of V6GT x2
M/B: Asus P8P67
VGA : Asus GTX570
Ram: G.SKILL F3-17600CL7D-4GBPIS CL 7-10-10-28
PSU : Scythe Stronger 700W plug-in
http://img40.imageshack.us/img40/2790/2500k51ghz1.jpg
http://img401.imageshack.us/img401/6244/2500k51ghz2.jpg
@mazaki01
Read the 1st post. You must have Linx runing the 21st run when you take the screenshot.
Your gflops are low as sh*t even for non AVX windows.
Thanks! Although I'm running HT off for now, I might need maybe 1.375 - 1.39 range to do HT on. For gaming HT off might actually be better option. With P6T6 I have to run 25 multi and higher BCLK or the multiplier will fluctuate. :down:. Swapping for the R3E today, maybe I can run high multi and lower bclk..and maybe lower voltage as well, dunno. :)
http://image.ohozaa.com/it/th100_.gif
OS : Windows 7 - 64-bit
CPU : Intel Core i5 2500K @ 5.3037 GHz / CPU Vcore 1.600 V. [#L041]
M/B : Asus P8P67 Pro
RAM : G Skill XM 2GB/1600 x 2 / DRAM Vcore 1.550 V.
VGA : Sparkle GTS 250
HDD : WD 640 GB AAKS
DVD RW : -
PSU : iCute PRO 900W
Case : -
Water Cooling : Swiftech
http://valid.canardpc.com/cache/banner/1717859.png
http://image.ohozaa.com/t/b2c/hhvo1.jpg
http://image.ohozaa.com/t/ead/p180311_20.42_01].jpg
@TWK_OCZ: how many bikes do you own??? lol
ontopic> very nice temps! u using an Apogee XT block right? is that pump a MCP655? testbed looks awesome :D
still you should edit your post to meet the first post standard.
Can you please add me to the Gulftown table with this run.;)
needforspeed| Core i7 990X [6C 6T] @ 4951.4MHz | 1.587 | ASUS Rampage III Extreme | Water | 3045B094
OS : Windows 7 Ultimate x64 SP1
CPU : Intel Core i7 2600K @ 5GHz / CPU Vcore 1.455v Batch#L042B243
M/B : Asus Maximus IV Extreme BIOS 1303
RAM : G Skill 4GB DDR3-2133 7-9-7-20-1T DRAM Vcore 1.67v
VGA : MSI N560GTX Ti Twin Frozr/II OC
HDD : (2) 64GB Sandforce SSD RAID 0
Samsung BluRay Writer
PSU : Corsair AX1200
Case : Corsair 800D
Water Cooled
http://i580.photobucket.com/albums/s...-20-1T_AVX.jpg
batmang | Core i5 2500K [4C 4T] @ 4998.3GHz | 1.43 | Biostar TP67B+ | Air | L052A782
http://img.techpowerup.org/110402/Capture013572.jpg
Does AVX stress sandy cpus that much harder then not using AVX or just alot of people just not updating to enabled AVX?
Its taking around 1.38v .. This is the second 990x of same batch , the first did 1.36v.. but got fried with turbo V.
This CPU needs a little more juice, but seems much cooler...:
http://www.xtremesystems.org/forums/...d.php?t=268948
I am tying to get 5ghzs stable (>100 gflops) but no luck yet..
