3200+ Venice
0519 LBBLE APAW
neo2 Plat. no mods and really @#%^ voltage readings
Bios setting is 1.57 yet putting a meter on the mobo shows 1.75 and core center shows 1.65 +/-
water cooled.
the 3 pictures are simply reference of different settings.
my ram is really limited as this ocz pc4000 rev2 really isnt the best overclocking. although running ram at 133mhz allows for 340+ HTT i try to achive 1:1 as running a divider just creates a severe lack in memory performance. it makes the overclock not worth it as your mem thruput just suffers severely. The first picture reflect 166mhz Dram the last 2 reflect 133mhz.
Prime 95 does not work for any of them BUT SP2004 runs perfectly for all of them. why ? i do not know....
SuperPi 1m does pass on all 3 settings which is good.
With the irregular voltage readings im getting and the minimal 1:1 clocking im not getting the speeds id like. but the picks you see are what i am getting thus far.
The cpu is only 4 days old and im able to go higher with less voltage each day.
