Asus EAH4770 non-reference PCB:
http://img440.imageshack.us/img440/2639/adp3290.jpg
http://img440.imageshack.us/img440/7972/shimps.jpg
help me more please
FB to VR, VR 100kOm to GND, or otherwise?
help me more please
Factotum, 47k ohm is what? Resistance between FB and GND?
Why did You measure that resistor? Is that connecting FB to GND?
You need to know resistance between FB and GND.
thx.
from datasheet:
http://img717.imageshack.us/img717/2097/pdf.th.png
FB and GND - where?
You have to find some bigger GND point near that IC. You found FB allready, so just measure resistance between FB and GND. Remove card from PC before that ofc!
Always double-check all measurements. For example between directly pin4 and pin18.
If 1,1k ohm is right, then 20k ohm VR works fine.
double-check and done :banana::banana::banana:
Asus EAH4870 1GB non-reference PCB:
http://img201.imageshack.us/img201/7972/shimps.jpg
thanks to all :kissbutt: :kissbutt: :kissbutt:
bad vcard =((
Vgpu=1.3V:
http://img185.imageshack.us/img185/5907/13v.th.jpg
Vgpu=1.35V
http://img185.imageshack.us/img185/999/135v.th.jpg
:shakes:
@ overshocked- I have benched 1.6v without OCP..on 4870 mod... as well, the GPU did much better with more 16v input caps. I added 6.3v output caps, with little to no gain.
Thanks cl3p20,
So what like 1000uf caps?
So any of these will do?
http://www.mouser.com/Passive-Compon...FR6Z2AodAXR8Jg
Thanks.
Yes those will work just fine. I like Nichicon.. but they are expensive.. Chemi-con work good too and better prices.
kk thanks m8,
PMed on OCN.
So i got a cheap 4850 to replace my dying 8800GTS 320mb.
4850 512mb reference design
accelero S1
Vrm-heatsink sawed of the stock heatsink
Medium-speed 120mm fan blowing on vrm heatsink
But seems i got a crap overclocker...
Stock 675/1025 stable
1.3v 735-740
1.35v 760-780
1.4v 800-810
Currently running 800/1000 1.39-1.4v
Am i doing anything wrong? Only using Vgpu mod since ram mod has killed cards. Using the stock bios.
Max temps after 2 hours of Battlefield Bad company (roomtemp 23-24°c , summer!)
Core 52°
DISPIO 52.5°
MEMIO 65.0°
SHADERCORE 57°
Seems okay, certainly with hot ambient temps. I have decent caseflow and the 120mm is blowing on the ram, it's fine without ramheatsink.
But i was wondering, has anyone been running his 4850 on 1.4v for 1year+ ? It's only a 60euro card but it'd still be silly to blow it up!
Playing Bad company at 1280x1024 All high 2xAA and smooooth gameplay! Too bad i have a P35 16/4x motherboard or i'd get a second one for crossfire
HI any1 can help me with a pencil mod
for my 4850 Video card ? Is a his 4850
and has a non reference pcb ,
can any1 point me
where is the resistor
i need to shade?
His 4850 Fan Edition....
Also His has a 4830 fan edition same
Pcb maybe some1 know how to do a pencil on that !!
http://img691.imageshack.us/img691/3355/img4463cpia.jpg
http://i265.photobucket.com/albums/i...re4850_mod.jpg
Its still the R685 resistor. ;)
So the resistor i need to shade is R685 ? on other pictures i saw is r1687 like in this picture :http://yfrog.com/gi4850shphj the bord was a 4850 sapphire
and also same card a person told him to do like in this picture http://yfrog.com/5bvmodareawm9j
but the guy shade the r1687 resistor and it worked like in the 1st picture ! Also for the stock PCb the read of scheme is not like in this picture ??http://yfrog.com/jv4850stockj
Maybe im wrong but if im not the r1687 resistor is shade !! Thanks for your Help
Hmm..do you have a DMM to see if the resistors are connected, I cannot make out the paths visually from the pics, and have sold my 4850's. The R685 is just adjacent to the location the other users mod'd from..they could be connected..
I´ve searched for days after an hardmod for ASUS 4850 TOP mem mod.
Got the GPU mod finished but I want to mod the memory too :)
Hope some one knows!
Im not sure if all 4850 TOP have the same pcb. If yours have same I had, then all you need to adjust Vmem is a 100kOhm VR between the blue marks. ;)
http://img713.imageshack.us/img713/1740/cl3mem.th.jpg
