Originally Posted by EtherealRemnant
Okay so this is my first post here.
Long time lurker and I think its time. :)
Anyway, I have a Core 2 Duo E6300 that can hit 3.2GHz on a DQ6 (and I didn't even get a chance to tweak it much before I returned that board for lack of compatibility with everything under the sun) but on this board, which I bought from reading a few pages in this thread, it will not overclock at all.
I can raise the bus to 276. That's it. I've played with different BIOSes, all the different settings, disabled Watch Dog, C1E, and EIST, and still.. nothing.
Any time I tweak the settings at all, I get the three beeps for memory failure and have to reset.
I have 2 gigs of OCZ Platinum Revision 2 (OCZ2P800R22GK) that worked perfectly in the DQ6.
I'm really bummed out right now... it was totally stable on the DQ6 but on the Bad Axe 2, it won't budge at all.
Any ideas? I'm completely new to Intel overclocking (the last Intel system I built was an old school Celeron back in 2000) and this is driving me insane.
Also, this board runs the processor at least 8 degrees hotter than the DQ6 did and yes, I cleaned the proc with isopropyl alcohol as well as the heatsink and applied brand new thermal compound both times (the same stuff, roughly the same amount).
Either the thermal readout on the DQ6 was wrong or the Bad Axe is wrong. It says that both cores are running 57C right now with totally vanilla stock settings and when I load them both to 100, they hit 74C before I get nervous and stop the experiment.
I hope I'm just doing something stupid and that I really didn't make a bad choice getting this board. I'll be really upset if I have a bad board since Microcenter won't let me return another one.
