What does that mean?Quote:
^^ Leet... elite ... like 1337 H4x0r.
Probably nothing as far as oc. leet or 1337 is h4XXor for elite or cool.
http://www.google.com/search?client=...utf-8&oe=utf-8
I honstly think leetspeak is pretty silly but to each his own or is that pwn?
CABNE 0540 APMW ...1207.
I m still testing it , 32M passed @ 3ghz , 1.64v
1M passed 3031mhz , 1.67v under watercooling
but i think , this cpu can take more vcore ...
http://users.skynet.be/pt1t/144/3031_1,67v.PNG
Damn I think ewiz messed up my order.. it says RMA under order status? Why would it say that.. I haven't even had the chip yet.
Anyway do you guys know where there are any good steppings for sale.. I think I'll cancel this one from ewiz because they are seriously pissing me off, they have no more stock and I bet they gave my damn chip away..
those new CABNE's just look like the CABYE if I see those result :stick: ( at least when I look at my 148 CABYE )
Great, I hope mine performs similairly well! Did you get yours from computersmsa?Quote:
Originally Posted by Pt1t
yepQuote:
Originally Posted by perry_78
Fresh of the FedEx truck from Monarch Computer...
Should I be going :banana: :banana: :banana: 's
Looking back through the thread it seems most people are running MAL of 8-9, and preamble of 6.5-7.5 at 3.0ghz. Do you guys have that set in bios, or do you change it after booting into windows with a64 tweaker? Anything above 7.5 MAL blue screens on me before getting to windows. I have tried changing it with a64 tweaker, but it freezes on me. I have 3.0ghz sort of stable. 1m, 4m 8m pi pass, but fail 32m about half way through. Thinking that this may be why. Thanks.
Setup:
Opteron 146 CABYE 0536 GPMW Retail, from Monarch
Oh forgot cooling, was done on cheapo Tt Venus12 really well lapped
DFI nf4 SLI-DR, 510-2ModFix BIOS
OCZ PC3200 Rev2 TCC5 2x512MB RAM
OCZ PowerStream 520W
for rest look at sig
Windows XP Pro x64 (64-bit)
http://www.xtremesystems.org/forums/...id=39046&stc=1
THIS IS WITHOUT IHS, I FOUND OUT THAT THERE WAS HORRIBLE CONTACT BETWEEN IHS AND CPU CORE, max spi1m along with spi8m before was 2.95GHz with same settings, AND THIS CHIP RUNS HOT LIKE S*IT, was 62C loaded before, don't know how much now after taking off IHS :D I'll keep you updated
EDIT: Hmmm, 3004Mhz is my max spim1 stable with above settings, will try more vcore :D Here's Snadra shot:
http://www.xtremesystems.org/forums/...id=39047&stc=1
EDIT2: Bad news, 3012 is the max on this cpu with 1.63 volts, won't try any more volts
Originally Posted by 4X4N
combination of MAL 9.0 and PRE of 7.0 usually work pretty well..these opty are tricky! do it in BIOS and see if you can even load up the built in memtest, if you can't....then don't bother to load up windows.
im havin trouble getting SP2004 and OCCT stable at 2900mhz / 1.54v
everything else is stable, 3dmark05 (4 loops), stresscpu (3days continuously), superPI (1m - 32m), CS:S (bout 4hrs of play).
im thinking its my ram timings etc...
http://img20.imageshack.us/img20/521...timings7wx.jpg
anythin other info u need just ask :), also rest of system specs r in sig
Ok latest update :toast: :
http://www.xtremesystems.org/forums/...id=39049&stc=1
Still unoptimized, 23min xx sec is achievable, I'll work on that tomorrow, now time for some BF2 ;)
Mine doesn't like sp2004 AT ALL. I can game and run OCCT at 3000 1.5v.
But my chip takes 1.425v to even prime at 2800.
Not sure what's going on, but as long as everything else runs stable, I'm happy.
Ok, since I am having trouble getting anything over 2.8 100% stable, I decided to try for a max clock. 11x278 1m pi pass. Broke into 27 seconds :woot: Opteron 148 CABYE 0528 GPMW
well, randomly, i did my 290x10 stable with at least 1.55v as opposed to your 1.54 *shrugQuote:
Originally Posted by NiSMo
Opteron 144 CABNE 0540 AMPW with HIS under WC
http://valid.x86-secret.com/cache/45631.png
http://users.skynet.be/pt1t/144/CPUMARK_405.PNG
Hi,
Now I have my new opteron...
Here you are the sigle:
CABGE 0536VPMW
How do you think about it?
This afternoon I will test it....
Bye! :D
not bad....what's it stable at :toast:Quote:
i m still testing, for now , 4h prime95 , 3ghz 1.64vQuote:
Originally Posted by dinos22
damn that's just tops...you belgians are crazy mofo OCers with your super high vcore with ghetto WC hehehe :toast: :toast: :toast:Quote:
The 0540 needs more vcore than 0530 :slapass: , i only give what it want :DQuote:
Hey! duds... is there anyone using socket 939 opterons here?
939 Opterons ??, why would we use those :rolleyes: (jk)Quote:
Originally Posted by Pirated
