O.O
Radical-top ddc and 90-degree compression fittings with alu stuff? *commits seppuku* ;)
O.O
I know your oppinion about my setup creidiki ! ;-)
:lol2:
lolz:slap: :rolleyes:
2fink, did you cut out your back plate where rad-plate-fan, seems like you didnt...
My first attempt up to h20
Attachment 49964
Attachment 49965
Attachment 49966
Attachment 49967
Attachment 49968
the following components:
-Alphacool AGB-Eheim 1000 Station 12Volt
-Alphacool NexXxoS Xtreme II + 2 x Nexus D12SL-12
-CPU Alphacool NexXxoS XP
temperatures are:
+- 27 idle
+- 38 stressed
I have bought that exact case for my new rig. But I am going to mount a tripple mother in the roof :DQuote:
Originally Posted by 2fink
How is the case?
updated with new nb cooler
http://img460.imageshack.us/img460/7...5mediumcn3.jpg
hi guys , do you think green UV liquid mixes with Blue UV lighting? is the result nice?
i am thinking about green water and blue fans+cold cathode
umm lol , id test it before putting it my loopQuote:
Originally Posted by ea6gka
it might come out looking like gunky " havent cleaned my loop in years" swamp thing green
No such thing as blue UV m8, they are blacklight, and they only come in one 'colour'.
Green 'UV' reactive stuff works well with blue aslong as it aint overdone imo.
i have seen blue cathode lights that illuminate UV reactive stuff like cables etc so i think there must be blacklight and blue UV reactive cold cathodes , forgive my ignorance :D if i am mistaken
currently i have 2 blacklights with green liquid
heres a pic, plexy is to be installed soon
http://img529.imageshack.us/img529/4449/1me6.th.jpg
suggestions welcome :D
no, i didnt. i only cuttet some parts out for the 230V pump-cable. theres a blowhole, where i normally had a 120er fan blowing out. now the fan is on the outside of the case sucking air from the inside.Quote:
Originally Posted by septim
greetings
thats becuase all VFD produce UV it is the phosfor that creates the light that you see, blue just allowes more of the UV to escape. black lights with proper filter will be purpolish, but a phosor in a blue dye will flourec blue.
@ Cl4w:
What type Nb is that? looks ok, I need to find one for my PC-DL (I875 chipset).
it looks alot more restrictive than it need to be.
mcw30 would be your best choise, it has a flat bottom only.
Looks like a standard Unnecessary-Restriction-Issue Alphacool NB.
Can some one PLEASE tell me wat dvd burner that is.... i want it :toast:Quote:
Originally Posted by Shakermaker
its pioneer's retail drive for the home end userQuote:
Originally Posted by Vandread
just go to their website for the model#
@Vandread
you got a pm !
just got my done.
Thanks for all d comment, suggestion & advice..
all up..just need some bling bling..
thanks..
http://i18.photobucket.com/albums/b1...f/DSC00431.jpg
http://i18.photobucket.com/albums/b1...f/DSC00432.jpg
http://i18.photobucket.com/albums/b1...f/DSC00433.jpg
http://i18.photobucket.com/albums/b1...f/DSC00429.jpg
http://i18.photobucket.com/albums/b1...f/DSC00443.jpg
http://i18.photobucket.com/albums/b1...f/DSC00438.jpg
http://i18.photobucket.com/albums/b1...f/DSC00441.jpg
http://i18.photobucket.com/albums/b1...f/DSC00440.jpg
http://i18.photobucket.com/albums/b1...f/DSC00436.jpg
wiring still a bit messy.. u dunwan to see wats behind the motherboard tray. is like a map..lol.
sorry for the photo quality.. only hv a camera phone..
jesus, how much additive did you put in that loop?
You sure that aint some strawberry sirup? :D
probably 7% of ZEREX only..
it only look so bright & vibrant on the last pic.
maybe cause of flash.
I would get some ramsinks on your card dude.
7%... I use 1 tablespoon...
1 tablespoon of ZEREX with a bottle of battery water??
hmm...isnt tat too little??
label written mix coolant 5% with 95% distill water..
Ramsink.. later on.. SWiftech RAMSINK is overkill.. on d pricey side..
still looking around.. still need to soruce some other stuff as well.
some air filter element for d 3x5'25" bay... some screw for the top grill.
some sound damping for d pump and etc... and Bling Bling maybe..
