Thats amazing.
Thats amazing.
I could get 3970mhz at 1.36V Vcore
with NB@2600mhz at 1.25V
Good enough?
Itīs Prime Stable...!
no reboots at all...
Now I going to change my motherboard (Am2+) for Better overclocks and Bandwith
Currently is a Gigabyte GA-78GM- US2H no ACC.
I need a suggestion please :
I hope I can Get 4ghz Stable with one of there :
Biostar TA790GXBE 6.x with ACC or
Biostar TA790GXE 128M 5.x with ACC or
GA-MA785GM-US2H with ACC or
ASUS M4A785-M with ACC
Please suggestions!!!
=D
my system :
Phenom II 955 C3 CACAC 0952 cpu(3.970ghz, 1.36V) NB(2600mhz, 1.25V)
PSU CoolerMaster 460W
2GB Kingston DDR800
Shapphire HD 5770 VApor-x
Old Phenom II 940 "suicide".
http://valid.canardpc.com/cache/screenshot/496913.png
http://hwbot.org/community/submissio...4_940_4320_mhz
CPU Model Used: Phenom II 940
CPU Full Stepping:20x
CPU Frequency:4320Mhz
CPU Vcore: 1.65v (I think..not 100% sure)
NB Frequency: I think lowest possible
HT Link Frequency:^
Memory Frequency: 864MHz
Memory Configuration (2x1gb, 2x2gb, etc): 2Gbx2
Memory Ganged/Unganged: Unganged
Mainboard Model:Foxconn A7DA-S
Cooling Type: Air
Windows Version and x86 or x64:Windwos XP 32bit
AMD Phenom II X4 925, stock voltage, 3,8GHz
http://www.part.lt/img/6c00814cf85ac...eaadd16374.png
hey all
Bobehud here and this is only my second OC first was with a locked 9750 quad that taught me a great deal stable for years after 20 hrs-max load prime no blend.I was at 2.75 now for a 2.4 chip doesnt sound like much bear in mind it was a locked chip.
Okay enough babble as i got this am to cl on my OC it just passed the 12 hr mark 3817 with a 955 c3 with 1.45vts to chip.
My question is it is keeping cooler temps at full load NOW than when i went to bed from 51-52c down now to 48-49c does the thermal paste need to get a better bond and that is the reason a better heat transfer..?
received my 955 c3 today. some quick testing, wanted to get a general idea of a max below 1.4v, not much room to tweak with this mobo (sig), but i'm satisfied so far. cooled by true 120 black with two low speed 120mm fans push/pull. hopefully 4ghz with a little more volts/tweaking.
http://i164.photobucket.com/albums/u...U-Zat38GHz.jpg
CPU Model Used: AMD Phenom II x2 555BE (unlocked to quad cores, all cores at 3.8GHz)
CPU Full Stepping: C3 stepping Batch: CACAC AC 1004 EPMW
CPU Frequency: 3.8GHz
CPU Vcore: 1.46v
NB Frequency: ??? (first time clocking AMD's not sure where to find this, FSB is at stock 200MHz though)
HT Link Frequency: 2000MHz (for stability)
Memory Frequency: 800MHz (for stability purposes at this point)
Memory Configuration 2x2gb
Memory Unganged
Motherboard: Asus M4A785-M
Cooling Type: Ultima 90 w/ yate loon 120mm fan
Windows 7 x64 Pro
Remember: I will still add you to the chart, but I don't patrol this thread often anymore. If you want on the chart, PM me your submission and I will update it. Take note that you must also post here. Make sure to include the information in this format, as it makes it MUCH easier for me:
Username
Model (940 BE, 955 BE C3, etc)
Stepping (CAC** AC ####****)
CPU Frequency
CPU Core Voltage
NB Frequency
Memory Configuration (2x2GB @ DDR2-867)
Motherboard
Cooling (Air, Water, Cold Air, Chilled Water, Phase, DICE, LN2, LHe, etc)
OS (2000/XP/2003/2003R2/Vista/2008/7/2008R2, 32/64-bit)
Post Number
Hi guys ! :) I submit my suicide score:
Username: Dreadlockyx
Model: 965 BE
Stepping: C3
CPU Frequency: 4212.31
CPU Core Voltage: 1.512V
NB Frequency: 2GHz
Memory Configuration: 2x 2GB (PC3-10600)
Motherboard: Crosshair III Formula
Cooling: Air
OS: Win7 x64
Post Number: 1684
http://hwbot.org/community/submissio...be_4214.31_mhz
PS: sorry if my english is bad, i'm french. :P
very good !!!!!! your forum is so good help me to much.thank you
Hi guys, I will try with my rig this night and post the result here....let's see if a get the 3.8GHZ stable.
I'm running BOINC 64 crunching for a good cause and I've got my OC at
3.9 ghz and voltage is at 1.38. My machine is on forced outside cooler air. While running BOINC @ 100% in an 80f room(loft area) and about a 68degee intake temp ATM, my peak load temp was at about 56c. Is that too hot for 24/7? If so I'll dial it back to 3.8ghz where the peak was like 53.5c.
Thanks for the advice!
User - slaveondope
Model - 955
Stepping - CACAC AC 1002DPMW
CPU Frequency - 4250mhz
CPU Core Voltage - 1.552v
NB Frequency - 2500mhz
Memory Configuration - 2x2GB Adata 833mhz
Motherboard - DFI LP JR 790GX-M3H5
Cooling - AIR
OS - Win7x64
Post Number - 1690
http://valid.canardpc.com/show_oc.php?id=1059330
3.8ghz sounds like a good spot for crunching imo and on stock voltage awesome.:up:
Better cooling that could keep you under 50c peak and youd be running 4ghz no problem with some more voltage.
I have been crunching 4.0ghz all week ;)
http://3800z24.info/Phenom/WCG-4.0ghz.jpg
Thank you I reposted in AMD section too.
Thanks! I'm trying to lower my vcore to see what I can get away with and remain stable hopefully lowering my temps.
Wow! I might have to invest in a H20 loop for my Thermaltake case.
http://img534.imageshack.us/img534/2772/cpuzg.jpg
User - Exlua
Model - Phenom 2 965 BE (125W)
CPU Frequency - 3900mhz
CPU Core Voltage - 1.424v
NB Frequency - 2700mhz
Memory Configuration - 4x2GB G.Skill Eco's @ 800MHz
Motherboard - GA-MA770T-UD3P
Cooling - Noctua NH-U12P SE2
OS - Win7x64 Prof.
Hi all.
I have a question. For the suicide list, isn't necessary Prime95 right? only the CPU-Z validation and screen?
Hi, this is my OC.
http://img408.imageshack.us/img408/2088/oc4020.jpg
By saint1926 at 2010-04-03
http://valid.canardpc.com/cache/banner/1117612.png
username: SAINT19
Model: X4 955 C2 (125W)
Stepping: Where can I find it?
CPU Frequency: 4020.17 MHz
CPU core voltage: 1.512V
NB frequency: 2000MHz (I'm not sure)
Memory Configuration: 2x2GB DDR2 @ 804MHz
Motherboard: MSI K9A2 Platinum
Cooling: Air with Hyper 212+
OS: Win 7 x64
I've got mine running cool thanks to my new H50 / Forced air/AC if I want it setup in my loft. Note my temps in the picture 39c at 100% BOINC load. This is my gaming and crunching at night config. For crunching during the day I throttle it back to 3.4 do to higher ambient temps.
http://farm4.static.flickr.com/3566/...1d965e13_b.jpg
http://farm5.static.flickr.com/4023/...5103854323.jpg
http://farm5.static.flickr.com/4060/...d10d90e75e.jpg
I'm ready for summer! By turning on my AC the idle temps drop to 17c and load is at about 32c at 3.96. I know it's ugly but it was cheap and fits my needs. I'm very happy. :)
http://farm5.static.flickr.com/4028/...7ed75c87b3.jpg
It took me long enough. :cool:
http://farm4.static.flickr.com/3552/...d9479b45_o.jpg
Here's mine
CPU Model Used : Phenom II X4 940BE
CPU Full Stepping : CACVC AC 0851EPMW
CPU Frequency : 3712
CPU Vcore : 1.5375
NB Frequency : 2025
HT Link Frequency : 2025
Memory Frequency : DDR2-1200
Memory Configuration :2x2GB
Memory Ganged/Unganged : Unganged
Mainboard Model : ASUS M4A79 Deluxe
Cooling Type : Water
Windows Version and x86 or x64 : Vista x64
Username : felix_w
Model : 940BE
CPU Core Voltage : 1.5375
NB Frequency : 2025
Memory Configuration : 2x2GB @ DDR2-1200
Motherboard : ASUS M4A79
Cooling : Water
OS : Vista 64-bit
Post Number : 1698
Validation : http://valid.canardpc.com/show_oc.php?id=1183014
Screen (~4hr Prime stable) :
http://i256.photobucket.com/albums/h...validsmall.png
(Notice that for 1.5375V set in BIOS and idle in Cpu-z, the voltage at Prime load falls down to 1.490V)
Nice temp under p95 load test!
http://farm5.static.flickr.com/4069/...7a63aa47_o.jpg
