terroristone,heres one of my templates for my Q9650 and the UD3P. you can give it a try if you want.
if it doesnt work you might need to mess with the mch ref voltage,up one notch or down one notch.also same with cpu ref.Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..................: Auto
CPU Clock Ratio ..........................: 8
Fine CPU Clock Ratio......................:
CPU Frequency ............................: 4.00 (500x8)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control....................: Enabled
CPU Host Frequency (Mhz) .................: 500
PCI Express Frequency (Mhz) ..............: auto
C.I.A. 2..................................: Disabled
Advanced Clock Control
CPU Clock Drive...........................: 1000mv
PCI Express Clock Drive...................: 1000mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 50ps
DRAM Performance Control
Performance Enhance......................: Turbo
MCH Frequency Latch......................: auto
System Memory Multiplier ................: 2.00D
Memory Frequency (Mhz) ..................: 1000
DRAM Timing Selectable ..................: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP......................................: 5
tRAS.....................................: 15
Advanced Timing Control [Press Enter]
tRRD.....................................: [Auto]
tWTR.....................................: [Auto]
tWR......................................: [Auto]
tRFC.....................................: Auto
tRTP.....................................: [Auto]
Command Rate (CMD) ......................: 0 [Auto]
Channel A
Channel A Timings Settings
Static tRead Value......................: 9
REST AUTO
Channel B
Channel B Timings Settings
REST AUTO
Motherboard Voltage Control
Load-Line Calibration.....................: Enabled
CPU Vcore...............1.32500V..........: 1.3875........or what ever your cpu needs
CPU Termination.........1.200V............: 1.380
CPU PLL.................1.500V............: 1.570
CPU Reference...........0.760V............: 0,924
MCH/ICH
MCH Core................1.100V............: 1.40
MCH Reference...........0.760V............: 0,939
MCH/DRAM Reference......0.900V............: Normal
ICH I/O.................1.500V............: Normal
ICH Core................1.100V............: Normal
DRAM
DRAM Voltage............1.800V............: 1.98......or what ever you ram needs
DRAM Termination........0.900V............: Normal
Channel A Address Vref..0.900V............:Normal
Channel B Address Vref..0.900V............:Normal
Advanced Settings
Limit CPUID Max. to 3.....................: Disabled
No-Execute Memory Protect.................: Enabled
CPU Enhanced Halt (C1E)...................: Disabled
C2/C2E State Support......................: Disabled
x C4/C4E State Support....................: Disabled
CPU Thermal Monitor 2(TM2) ...............: Disabled
CPU EIST Function.........................: Disabled
just got to find the right combination.
although ive had a couple of people been able to use the exact ref voltages and have it work.the good thing is,once you find
what your cpu and board likes you really wont have to mess with them anymore.
good luck keep us updated.PS most of my Q9650 templates are posted back around pages 67 to 90 in the ** Official ** Gigabyte UD3 P45 Series thread.:up:
