Anyone have any idea how to stabilize ram? I have Q9450 and 4x 1gb Corsair Dominator CM2X1024-8500C5D (yeh i know 4 sticks is fail to begin with but...). I can run fully stable 8x450 with 333fsb strap and ram on 1080mhz and VERY tight timings on 2.0V, i managed to run inteliburn test with 8x462 and ram on 1110mhz 15 passes, however prime95 blend always fails in ~5min, no matter what i do, dimm voltage on 2.3V, common preformance level from 7 (using on 1080mhz)-10, clock twister changing also doesnt help (using stronger on 1080mhz, tryed moderate and lighter without change), dram static read on disabled (using enabled on 1080mhz). So if anyone have any idea what i can try more, for example that dram controler voltages? dram skews (was chainging them already, only thing i managed to do is preventing computer to boot up)? As soon as i droped memory lower my computer seems stable. Currently runing 8x470, with 400mhz fsb strap and memory on 940mhz and its prime95 stable for ~30 min already...
