Originally Posted by
KTE
Yeah, it's just normal... they added support for new CPUs that's all. :)
What's max you're running on your cards stable?
With Spider there will definitely be tweaks uncovered yet for multil-GPU setups, I've just not had time to check. I would throw in >2 3870X2/3870 but its too much hassle and especially since I haven't even sorted the CPU side out yet, which is my main aim. I only used more than one GPU on the 790FX once and that was around 55 minutes to check if it worked, how many GPUs worked, what the issues were, if it benched using all of them with scaling, the full load power, which PCIe slots worked with what bandwidth, what were the fitting issues and which slots were slightly better, so can't say much.
