Hey all, been a while since ive been on here and some things have changed.
Ditched the q6700 for a q9550 E0, turned out to be a slight headache upon install.
Prior to, i set the bios (1814 at the time, 1893 came out the next day) back to default values for voltages, etc. tossed in the q9550 and got 3 pulses of the fans and lights upon power up then it shut down and was dead. Called Intel, and to my surprise, they painlessly issued an RMA and a week later had a replacement board.
Updated new board to 1893, and after some playing got the limits:
My FSB seems to be the limiting factor, with a max FSB of 475x6 @1.5v FSB and had to bump the MCH to 1.5 to be stable there. mem @ 800x400
After increasing the multi, made it to 475x8.5, or 4.0375Ghz @ 1.4125 vcore (default 1.325, core VID in CPU-z 1.250) with FSB and MCH both at 1.5
Now working on more conservative every day use settings. dropped to 460x8.5 @1.3875 and still working on memory (trying to remember how all this mem reference x mem freq works and the best way to step up through it).
Saw a strange thing, changed mem settings, failed to boot, went into maintenance mode, changed back, rebooted, entered setup to check settings, exited, went into OS and everything seemed to be fine. checked cpu-z and to my surprise, was running at 333x8.5 even though in BIOS was at 460x8.5. had to change bios settings around a few times, but it eventually worked its way out.
What have you guys seen as the max mem frequency with this board? saw 1760mhz (1333x333) with defaults while increasing FSB at 6x multi.
