G-Skill BHZ D9GMH Need some help
Hey guy's I seem to be stuck with this ram and dont really know where to set them so i can stay stable at 3.6 , whenever I run prime i fail exactly on the same test at test 2 80000 , the computer completly reboots , Ive been thru this forum like 3 times and tried tons of settings but nobody seems to have the same ram
:( I can run at 3.5 perfect
Can you guys take a look at my settings tell me what you think please:confused:
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9X
- Target CPU Clock: 3600 MHz
CPU Clock: 400 MHz
Boot Up Clock: auto
DRAM Speed: 366/667
- Target DRAM Speed: 800MHz
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control: 1.43125V
CPU VID Special Add: auto
DRAM Voltage Control: 2.310V
SB 1.05V Voltage: 1.150V
SB Core/CPU PLL Voltage: 1.95V
NB Core Voltage: 1.61V
CPU VTT Voltage: 1.60V
Vcore Droop Control: disabled
Clockgen Voltage Control: 3.85v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Enable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 117
DRAM Timing
- Enhance Data transmitting: Fast
- Enhance Addressing: Fast
- T2 Dispatch: Disabled AUTO
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: AUTO
- DIMM 1 CLK fine delay: ?
- DIMM 2 CLK fine delay: ?
- Ch 1 Command fine delay: ?
- Ch 1 Control fine delay: ?
Ch2 Clock Crossing Setting: AUTO
- DIMM 3 CLK fine delay: ?
- DIMM 4 CLK fine delay: ?
- Ch 2 Command fine delay: ?
- Ch 2 Control fine delay: ?
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL): 4
RAS# to CAS# Delay (tRCD): 4
RAS# Precharge (tRP): 4
Precharge Delay (tRAS): 12
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
- Channel 1 Phase 0 Pull-In: Auto (each Phase when enabled = (Common tRD - 1)
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
http://i84.photobucket.com/albums/k7...ocunstable.jpg
skip the skills till bios fix
yo these sticks are great and stable as long as long your oc doesnt require going past 800 ghz becuase of some of the setting's ive gotten no help with thru g-skill
go with brother esau ram choices he has been good with this board, plus he,s tested diff types of ram on this board
