No kidding. Hey EVERYBODY!!! Include your damn batch code when posting such nice results. God damn!
Question now is. If you can hit 3.6 with only 1.3v what can it do with 1.4 or 1.5v?
So if it takes your L737B 1.33V to reach 3600MHz stable, then how much do you give it at 4GHz 2x Orthos stable? I would think about 1.53V right?
The reason I ask is because my L737B325 also needs 1.32V for 3.6GHz and 1.432V for 3.825GHz so was wondering how yours compares.
Look carefully, 1.33V is my XEON 3220. The xeon is a G0 Week 17A. I cannot get this xeon to do 4ghz because of temps.
I have another q6600 that can do 1.29V 3.6ghz. This cpu however can do 4ghz. I'm still trying to get it prime stable but it should be doable at around 1.45v
Right now the temps are quite high at 4ghz but a lapping should fix that problem since the cpu is concave and the tim needs to cure.
just ordered a chip... it'll be batch #737B011
hope it turns out to be a good one
I have been reading this thread from the start and have learnt a lot. My first build ever as in my sig. 24/7 use. 12 hrs prime and orthos stable both small ftt and blend. Air cool temps (72F ambient) are idel 42,39,38,38 and prime 4 thread small ftt 67,65,61,62 (speedfan and core temp both). Are these good for 24/7 use, minor gaming, photoshop, home videos, spread sheets etc? Would TR Ultima give me mor headroom? ( Ulltra extreeme wont fit)
Just put a L727B in a P5K-E. Gave it 1.4v and it went to 3.6GHz without a hiccup. Will push for more later, find out just how fast she can go, and update then.
My L737B, 10C water:
http://img526.imageshack.us/img526/7...1m44ghzcs3.png
4.2Ghz prime:
http://img522.imageshack.us/img522/6...9542ghzop0.jpg
I did some 3D benchies at 4.35Ghz.
http://img212.imageshack.us/img212/8...k06173kcg1.jpg
Does anyone have any info on L731A963? Just got that in the mail today, xeon x3220 g0 stepping
Yesterday I lapped my hot L740A740. And now with 10°C less the daily @ 3800mhz is a must!! :D
http://www.pctunerup.com/up/results/...800mhz1ora.JPG
3600mhz with 1,28V it's about 37°C idle and 50°C full under Prime95.
Nice!
Just finished my 3.6ghz Run on prime.
http://liquid-pixel.org/Images/comp/...13_12_2007.jpg
and CPUZ Validation
stats are on pic and in signature.
going to lap and install my L739A459 tonight, anyone have this stepping yet?
i hope it clocks as well as the L737
L737B064
It's not the max, just the daily config:
http://img264.imageshack.us/img264/3...00primebb6.jpg
Rbs.
:wave:
F9 bios is working great with P35-DS4 Rev1.0. Loadline calibration enabled I gained few MHz with same vcore compared to bios F6.:up:
http://img209.imageshack.us/img209/6...uistit4wl8.gif
Anyone have a L738B233? I just got one going to put it together shortly...
