Pretty funny.Quote:
Originally Posted by ghettotech
Im going the other way. Returning my DS3 board and getting the P5B Deluxe.
Im stuck at 400FPS with the DS3, and I cant run my Cellshock at PC8000 speed.
Pretty funny.Quote:
@emistral
Have u already try with fresh install of win xp? Or maybe boot with safe mode?
not even with a different strap?Quote:
Originally Posted by mbm
Dont know what strap means?Quote:
Tried with lower muliplier. Also tried with different divider.
No go for PC8000
hi guys i found this on the asus forum,hope its of some use-
Hi p5b,
I have managed to get the new audio driver 4580 from puzzleman in another thread about sound probelms. You can get it from here.
It is not the full install package. To install it you must go to device manager, expand Sound, video and game controllers.
Then you must right click on SoundMAX Integrated Digital HD Audio , then click on update driver and then browse to the location of the downloaded driver (At least that's what I did). Everything so far seems to be working pefectly EAX is enabled and Windows XP boots alot quicker.
Good luck and let me know how you get on.
here is a link to the file-
[HTML]http://rapidshare.com/files/2634578/Audio_Driver_4580_W2K_XP.rar[/HTML]
THX it works perfect.Sound OK- Boot 15 sec. faster
awesome will try when i get home after work. when was this driver released?
sorry guys i have no idea were it came from.i found it on the asus forum.
any ideas why my d930 wont clock as high in this deluxe as it does in the p5wd2.
i'm getting my e6300 on monday anyway but i'd ave liked to run it at 4 or 4.2ghz till then.
i can give you a link to were i got it from if you like?.
anyone seen any updated x64 drivers ?
The inf file says DriverVer = 09/08/2006 so it looks quite old, I wonder why asus haven't updated the official drivers yet.
yeah the latest ones i found were 4570 dated 07/25/2006 :(
ftp://ftp.asus.com/pub/ASUS/misc/audio/ad1988/
TI66ER how did you enable EAX? I see no option, also no soundmax console, maybe I shouldn't have totally uninstalled the old soundmax drivers first :/
not even a post beep with your settings.Quote:
Originally Posted by tam2
If the board is holding me back @ 345mhz thats pretty sad. Since i can drop the multi and get 395fsb i think it might be the chip.
anyone tried the new bios 804? is it any good?
I've been using it for about a week with no issues.Quote:
Originally Posted by GrimReaper
EAX is enabled in the options of the game you playQuote:
Originally Posted by baker99
as TI66ER said, it is not the full install package.Quote:
install the full (older 4570) package, then manually update the actual drivers using device manager
Originally Posted by TI66ER
Downloaded it and it says no archieve found when im going to extract it. The size is about 6 kb??Quote:
that new driver is giving me trouble. it does dec boot, but now i get crackles and my comptuer doesn't boot 3/4 times and it doesn't recognized some USB components now. great....i think i might just disable onboard and use old SB live.
@tam 2.i have just downloaded it twice to test.it extracts to 3.13mb.
Thanks! at last fast boot times \o/ installed via device manager and everything seems to be fine.Quote:
I have not tried a fresh install because I don't want to go through all the troubles of reinstalling everything, backing up things, etc...
I tried booting in safe mode as well with the 450Mhz FSb but still the same problem.
It simply freezes either on teh welcome screen or if I pass that screen, when it start loading windows, it simply stops.
And this problem does not appear in Vista.
Last night I flashed the BIOS with version 0711 and same problem. I used the o/c profile whre the memory timing are set manually (4-4-4-12) but this time I set the memory to 350Mhz. It worked. I have to increase slowly the FSB again to find the max.
By the way, all the voltages are set to the max except for Vcore set to 1.6V. C1E is disabled as well. I am stucked and don't understand how a bios update can stuff up everything. well done Asus !
And the worse and when flashing back with the version that used to work, it does not work anymore !
well turns out the usb not working was b/c i had a gamepad that was dying and wreaking havoc. new sound drops my load substantially to about 3-5 bars now vs 15 originally
The new 4580 audio driver seems to be working nicer for me as well. Not extensively tested yet though. Just boot times and navigation around windows has improved. (unsure about the other issues)
(From 15.5x to 8.5x on the blue bootup bar)
Dont know if this is offtopic:
Do i have to own some digital speakers to use the onboard sound or can i use my analog speakers?
I cant seem to get any sound when i use the onboard, so im stuck using my audigy 2 LZ.
Hi Ti66er,Quote:
P5B is actualy me :) posting under a diffrent nick on Asus forum.
The driver came from Asus Rep, and its NOT official Release.
the 4580 Driver will work only as an upgrade for 4570 DTS drivers that are already installed.
you need ot go to device manager->HD Audio SoundMax, Driver Tab ->and choose update driver-Then point it to that directory that contains the files.
I can confrim that it shortens the boot time, and it looks like the boot problem is allot better.
i still feel that browsing through folders isnt perfect. I still feel that without hte audio drivers i'm having a quicker overall feel with the computer.
I had undergone a massive computer crash (used partion magic , and never recoverd from it...so i started fresh.)
i'm still bulding the system.
Hope you guys can continue to be on the subject till its fully resolved.
