:welcome: welcome to XS. Your friend didn't have much info.:(Quote:
Tankguys is all out of the 165 CCBWE 0546 FPMW stepping. Man I hope it's a good one. I did another search and still no one has posted there results. The suspense is killing me;)
No it's 0550 UPMWQuote:
Originally Posted by cdelatte
:brick: :brick: :brick: :brick: :brick: :brick:
I MISSED FEDEX. They might try to send the driver back, I called them and tried to do anything I can so I don't have to wait until Monday.
I always go UPS because they offer same day will call at night and they deliver on weekends. Blah. We'll see if I like fedex or not depending on how today goes, lol.
You can always just go pick it up at the distribution center.Quote:
Originally Posted by foodfightr
just to help out everyones search for steppings,,,just received and started testing the following,,, opt 165
Opteron 165 CCBWE 0546 MPMW ( 0546MPMW )
Got it running 8+ hour dual prime stable so far at 2.8ghz and 1.5volts on water cooling,,,
gonna do some more testing when I get off of work but its already responding leagues better then my opteron 170 0543TPMW,,,, for me the TPMW stepping was crap and couldnt get past 2.7ghz even with 1.62 vcore,,,
so far so good with this stepping,,,,
My 0550 UPMW is currently at 2526 @ 1.4v (1.375 in bios). Temps around 31 with dual prime. Im going slow to make sure everything gets burned in, my motherboard is relatively new also.
Wow get this...Quote:
Originally Posted by Mysterfix
1:30 Fedex customer service guy tells me he is going to schedule a re-attempt of delivery and says they are having trouble contacting the driver but they will put the request through and as a precaution he asked me to sign the door tag incase I miss the driver again. (Believe me, I won't miss him but I signed it anyways.) I asked if they offer will call so I could pick up the package tonight and he told me they didn't.
2:30 I call Fedex to check the status of the re-attempt, wondering if they got through to the driver or not. This woman answers the phone. (I'm literally STEAMING F***ING ANGRY AT THIS WOMAN.) She says it is not in the system and it is too late to schedule a re-attempt. I explained I already placed the re-attempt request and I'm calling to check the status. She wouldn't even call the driver to verify any chance that it may not have updated in the system yet. She was lazy, unhelpful and unprofessional. She says I can come in at 7:00pm to get the package, but the place closes at 7:00pm. At this point I'm entirely confused and aggrivated.
2:35 I call Fedex again, unsatisfied with this customer "service" (or lack thereof). This woman is amazing! She placed the re-attempt, gave me a case number- took down my info. She told me the best way to go about will call, everything.
33% Customer Service.... I'm sticking with UPS from now on.
Where is yours from?Quote:
Originally Posted by Sorrow13
UPS sucks in this area and from the looks of it FedEx sucks in your area. lol I usually miss the FedEx guy and have to go pick up my stuff at there center, it's always there when I get off work at 5:00pm. Lately the guy will just leave it at the door for me instead of making come pick it up.Quote:
UPS has only made on ontime delivery to my house in 2 years.:fact:
I'm burning in mine too, just at 2.9 wich happens to be my max stable oc so far.Quote:
OH SWEETNESS...................................
FEDEX CAME BACK!
:party:
165 0550 UPMW (ZipZoomFly)
Sweet! :clap: Hurry up and throw that baby in and get to overclocking! I got mine down to 1.46v gonna prime tonight for some burn in action.:stick:Quote:
Who sucks now!?:stick:
Do you think I should gently prime it and push it higher and higher- or find the point of stability at 1.5-1.6 and then try to burn it in and reduce volts?Quote:
Just wondering if you guys think it would be a good idea or not to start pushing this chip hard straight out of the box.
Did you get your cpu yet :)Quote:
I always start out at default voltage and see how far it will go on that then I give it a bump of .1v and keep pushing until I reach my max OC.Quote:
Once I hit my max I start priming, if it makes it through the night on prime I reduce voltage and start again. If that works I up the OC and start to prime some more.
So push it up as high as you can go on default and start from there.:stick:
I'm showing 36^C under dual load at stock voltage dual priming at 2385 (9*265).... case is on its side with TT Big Typhoon blowing directly up and out of the case.....
120mm Intake At Front
120mm Exhaust At Back
80mm Exhaust At Top
I did a pretty good job putting a nice thin layer of AS5 and tightened the heatsink down pretty nicely- but do these temps seem a bit low to anyone else?
Ambient is no hotter than 23^C... I'm guessing it may be lower.
just got myself an opteron 170 0543TPMW
got it up to 2.6 at 1.41, ran a complement of 3dmarks01 and 03, superpi, Sandra, and half an hour of prime, all before my graphics card magically died.
Now I'm running off of the integrated 6150 video on my board and priming away at 2 GHz and 1.15 volts, beauty of it is that with both cores 100% loaded the temperature is 31 degree using stock cooler.
Also my batch number is 0408, anyway to tell if this is generally a good number?
Looks pretty good, altough, your temps may go up by a pretty good amount once you start to apply some voltage.
The only way to be sure is to overclock it and hope for the best.Quote:
Originally Posted by freddy418
Got my 0550 UPMW at Zipzoom, and i hadnt heard about this stepping until i got it. Some quick searching shows it to be a decent overclocker, which makes me happy. Id like to keep mine at low volts if possible, but you know how that goes. I havnt tried to max it yet, though ill probably get impatient soon enough.....
Well.... I'm using 10 minutes dual prime (SP2004: Small FTT - Stress CPU) as a quick stability test. What test do you guys use to make quick adjustments to your CPU speed?
I have the LDT Multi at 2.5 and a 1/2 Divider to rule out just about everything but the CPU itself.
165 0550 UPMW passed at 9*275, I could get in to windows at 9*285 but it would crash just after. Testing 9*280 right now... all at stock voltage.
I use prime and usually let it run for a couple of hrs. to see if it crashes if it doesn't then I raise the OC a bit and start over. I got really lucky with this chip, booted up at 2.7 on default vcore and went from there.
You booted right away at 9*300 with voltage and special at auto and it primed fine for a few hours?Quote:
Yep :DQuote:
