Nice. I like how most of the glow is on the tubes and not much else.
Just finished my first watercooling setup a few days ago :)
http://img124.imageshack.us/img124/8100/2ch3.jpg
Well... this was my last 2 liquid cooled systems.
The first one is a Socket 754 A64-3700 with an ATI X850XT-PE
Has a Danger Den TDX block and for the vid card, a Silverprop Fusion HL, with a Black Ice Pro 120.2 on the back of a Nikao Dragonfire case... I am not a big fan of pre-mods, but I kinda like this one and it was given to me free as a review case. The system has been flawless and no matter how hot it got here (around 110* F with about 85-90% humidity), it never went over 42*C
http://i25.photobucket.com/albums/c7...d/8be732e5.jpg
http://i25.photobucket.com/albums/c7...d/f878772b.jpg
http://i25.photobucket.com/albums/c7...dates-2013.jpg
And then there is this one... please ignore the mess... I didn;t build this one for show, it was all for the performance, and also I had no plans on keeping it very long.
It is an Opteron 144 on an ABIT AV8 3rd Eye (with Uguru clock) motherboard, a gig of OCZ and a Hercules Prophet 9800 PRO vid card.
The cooling is an Arctic Web, 437watt/24volt Peltier block powered by a meanwell S600-24, and to cool the fluid it has a Bonneville heater core with 2 x Aerocool 140mm Streamliner fans, and also a Black Ice Pro 120.2 with a pair of Yate-Loon fans on it - the Opty ran, with an overclock of 334FSB @ 1.6 core volts, giving me about 3ghz
it's kind of a mess, but the thing ran, under full load, around -10*, -20* at idle. Here it is...
http://i25.photobucket.com/albums/c7...b3-2006005.jpg
http://i25.photobucket.com/albums/c7...b3-2006015.jpg
http://i25.photobucket.com/albums/c7...1/7679da75.jpg
http://i25.photobucket.com/albums/c7...1/03aac826.jpg
http://i25.photobucket.com/albums/c7...g/ded5f700.jpg
http://i25.photobucket.com/albums/c7...g/d9f049b0.jpg
~NortH~
This seems as good a place as any to make my first post. Here's my watercooled setup, it's an Asetek kit that I got for £29 and added an Antarctica LGA775 waterblock. My system isn't very extreme so this is more than enough for my needs - it's more geared towards being quiet, hence the large lump of iron sitting on foam underneath the pump to decouple it from the case. Fans are Yate Loons @ 7V and the hard discs are suspended in the 5.25" bays, so the whole thing is very quiet. The main drawback is the size of my case (Antec SLK3700AMB) which forces me to have the radiator at the front. It's all a bit messy at the moment, I'll do some cable tidying when I get some quieter fans delivered (next week hopefully) and I still need to get hold of a neater Y-adaptor for the waterblock (the kit didn't come with anything so I had to go to B&Q and grab whatever would work!)
http://www.charlaph.plus.com/rig2.jpg
Welcome to XS, strap in and hold on:D (I KID I KID)
hey, you may not be as insane as the most XS'r but you still did at least a little modding to your case, and its doing what you want right? Meaning it is quieter then it was. That counts for something.
I can see lots of room for improvement... well, there isnt a single thing I wouldnt upgrade, but there you go =p
That is one purdy setup north. Yay for blue.
@NortHWizarD:
wow 437w pelt that is massive, should even cool a dc quite good!
My new setup.
My new custom Alphacool setup
http://img.photobucket.com/albums/v608/webbo10/7.jpg
See HERE for worklog.
my first DIY watercooling, only just finished.
http://www.vexed.pwp.blueyonder.co.uk/images/wc2006.jpg
my mate had to take an arty piccy with his DSLR lol, i think he did a good job tbh :)
2X120mm RAD
L30 Pump (1200l/h)
MCW6002 CPU Block
XSPC GPU Block
XSPC Drive Bay Res
1/2 Pipes
(yes i know ive got the wrong cpu block for the setup lol, i brought it before the rest when i was doing some chiller stuff)
Can u give us a non artistic pic...? :p:
what do you mean, wrong cpu block? id say right one considering your pump....
I have changed gpu and added waterblock for chipset after this picture was taken. It is three triple 120-rads in there. Also, I have added a fan in the back of the case that sucks out the air of the case, meaning air coming in through rads.
http://www.loppmarknader.se/blossa/2.jpg
Ohhhh... dual opty... Cool. :) How is that setup in keeping your components cool?
42-43 degress on CPUs and around 45 on the X1900XTX gpu. But when benchmarking I have to add some more fans. I have two fans below the rad in bottom that is running when benching. They also work as a vacuum cleaner. :DQuote:
Originally Posted by Got Chow
EK Waterblock mounted.. really nice, I love it! ;)
http://www.4eweb.de/pc/tj07/15.jpg
http://www.4eweb.de/pc/tj07/16.jpg
http://www.4eweb.de/pc/tj07/17.jpg
http://www.4eweb.de/pc/tj07/18.jpg
http://www.4eweb.de/pc/tj07/19.jpg
http://www.4eweb.de/pc/tj07/20.jpg
Nice rig but your reservoir water :cool:
The laing has too much power..:/
Nope, thats what happends when you put too much additive or dont rinse your loop well. =/
And a t-line and on the top from the t-line the reservoir?
dam those tj07s look really slick and spacious
They doooooo i got one... :banana: (but damn it was expensive :p )
krueml what cdrom/cover thing are you using?
PS: any one know a silver or alu 5 or 4in3 harddisk s-ata swapbay?
I found one... it costed 1200 euro's :stick:
I'll post some pics when i got my setup filled:
MHQ Dualheatercore with shroud and 2x120mm (38mm) 220 M3/h (cubic? no idea)
DD TDX Brass top
Laing DDC-Pomp 12V Ultra
DD Fillport (yeah i know....)
very old ugly maze4 gpu, probably will upgrade to new blok with new card...
http://img116.imageshack.us/img116/9...9custom9pf.jpg
http://img128.imageshack.us/img128/9...2custom3cg.jpg
http://img128.imageshack.us/img128/7...3custom9zl.jpg
http://img116.imageshack.us/img116/5...2custom0pd.jpg
http://img199.imageshack.us/img199/4...1custom2ft.jpg
http://img305.imageshack.us/img305/4698/010100020oq.jpg
http://img101.imageshack.us/img101/6977/010100031ky.jpg
http://img101.imageshack.us/img101/6343/010100047ou.jpg
http://img529.imageshack.us/img529/6863/010100049fc.jpg
http://img529.imageshack.us/img529/371/010100066do.jpg
http://img529.imageshack.us/img529/8359/010100109kz.jpg
http://img97.imageshack.us/img97/7167/01010001vf9.jpg
http://img301.imageshack.us/img301/2148/01010005ct1.jpg
http://img101.imageshack.us/img101/355/01010002bm2.jpg
http://img97.imageshack.us/img97/4730/01010007dj0.jpg
http://img83.imageshack.us/img83/373...8customae2.jpg
http://img301.imageshack.us/img301/5...0customow1.jpg
http://img186.imageshack.us/img186/6190/01010001ko2.jpg
http://img158.imageshack.us/img158/9620/01010002ym7.jpg
Ambient temperature : 27-28º
@ 5v @ full
http://img439.imageshack.us/img439/5334/lowwz7.th.jpg
45º
@ 12v @ full
http://img439.imageshack.us/img439/9866/highwl0.th.jpg
43º
@ 12v @ idle.
http://img503.imageshack.us/img503/2586/idleaw2.th.jpg
36º
http://img133.imageshack.us/img133/6...lo15gr9.th.jpg
http://img149.imageshack.us/img149/1...lo39oc9.th.jpg
http://img135.imageshack.us/img135/1...lo17ya4.th.jpg
http://i38.photobucket.com/albums/e1...h_DSC05119.jpg
Nice rig, but I was distracted, that dog picture is possibly the cutest thing I've ever seen in my entire life.
