I really like the looks of that block!
DT Sniper with other engraving in the top, correct ? :)
Very nice!
If only the copper were cleaner/polished.
WOW! Someone slapped that sucker with an ugly stick.
It's definitely very utilitarian looking. Will you be reviewing it budnymania? Where do you post your reviews? Curious about the noise
Yes. You can see the link then on my FB page. Noise is ok, because itīs a pwm controlled pump which runs with max. 50% most of the time.
As do I. Liked it enough to buy the first one off the assembly line.
That looks great. But it seems like it would be a lot of work to keep it polished if you are going to have it exposed in your setup
You see the gloves ? :)
Yeah but over time I've found the exposed copper in my build just loses its sheen. It really does look cool. If people have good luck with it staying shiny, it's something I'd consider down the line
