OK, so I removed the Zalman 9900. The AS looked even on both surfaces with no missed spots. I cleaned it off and did the straight edge trick , neither of the two surfaces are totally flat but not off by more than about .001".
I cleaned and conditioned the two surfaces and this time I used the supplied Zalman thermal comound and re seated the cooler.I noticed that the Artic Silver I was using was AS3, not 5, it is an old tube. Anyway, my Temps are better but still nowhere as good as I would expect. I am down on average 10 C. from what I posted earlier. Both Real Temp and Core Temp agree and read the same. 50 53 48 52 so it is much better but not great, especially for 3.2 Ghz. Do you think liquid cool would make that much difference with no load? One other thing is that I am running with an open case right now so my air flow may not be optimum although I do have the front and rear case fans running at full.
