has anyone found a replacement for the chipset cooler ?
Also, the benchmarks work fine in Sandra. Just don't try to read anything on the smbus.Quote:
Originally Posted by wa2000
what about the swiftech mx-159cu. it comes with a clip as to allow you to use the hooks found around the NB chipset.Quote:
Originally Posted by jetjaguar
I contacted the SETFSB team and they answered me. They ask me some informations so that they can work on a pll for the XBX2. There will be surely a prog to oc on windows soon :D
Not stable enough. It'll shift around way too much. Clips are short too...so, you'd have to either bend them or find some other way to mount it.Quote:
Originally Posted by shimmishim
hmm while i was orthosing the other night .. i touched the nb heatsink and it was still cool and this was with 1.7v thru it .. so maybe it doesnt get hot ?
or maybe just add a small fan on top of the heatsink ???
i would take the stock heatsink off to apply some as5 but those clips that hook underneath the motherboard scare me
I can boot up to 3.9 on this mobo with air cooling, and this chip needs 1.65v for anything more.
http://valid.x86-secret.com/show_oc?id=165195
As far as i975x mobos go I think it's great. My second favorite mobo is the P5B deluxe wifi, which is 965.
The stock heatsink comes off in about 5 seconds. Just spread the fins where the black plastic clips hook in and everything will come apart pretty easily.Quote:
o so u dont have to take the clips off from under the motherboard ??Quote:
Originally Posted by gtj
do u think its worth putting some as5 on there ? also is there a way to monitor the temps of the nb ??? in windows
and one last question what size fan do u think i could fit on it ? 40mm or 60mm ?
thanks
Thermalright HR-05 fits fine. Just gotta tilt it a little. Damn thing gets pretty warm.
Question for gtj and others...
I overspent on the memory I purchased and am thinking about getting something cheaper. Is this the correct part for the OCZ Plat R2 memory I see in some sigs?
http://www.newegg.com/Product/Produc...82E16820227139
Any issues with this memory at all on the BadAxe 2?
Thanks!
-scaryogre
Originally Posted by situman
does it fit though with a tuniq tower 120 installed ??
and it gets warm ?? hmm my stock heatsink is cool
also any pics of the hr05 installed ?
my stock stays cool too but i'm only putting 1.6 through the NB and I've taken off the stock TIM and put AS 5 on (first thing I did when I got the board).Quote:
The stock TIM SUCKS big time. It almost had a fabric-ish type of consistency. I had to use goo gone to get it off.
hmm wondering if i should take it off and put some as5 on it .. or get the hr05
The thing gets hot enough to burn my fingers. I have watercooliong so I'm not sure how it will fit with ur Tuniq. I'll get pics up tonight if I'm not too lazy.
hmm which do i trust
IDCC or CPUZ 1.38 regarding mem
IDCC is reporting my mem at 720 while CPUZ is reporting its running 1:1 at 900 ???
Correct. That's the benefit of the soldered in loops. You can change the HS without removing the MB. Definitely put some AS5 on there.Quote:
I'm not the guy to ask about what fits because I WC mine (for silence not performance).
Those are the ones. Rock solid for me.Quote:
Originally Posted by scaryogre
This thread seems to be the only one that seriously covers about 975XBX2. I can't seem to find a decent one these days about it. I was wondering whether a guide can be compiled like for the other mobo's cos seriously sifting thru 65 pages for nuggets can be really frustrating
Here's a few tests from me at 3.8GHz. Once you unearth the 'quirks' with this board, it's a decent performer.
Crappy untweaked Spi1M:
http://img.photobucket.com/albums/v4...uperpi1m_3.png
http://img.photobucket.com/albums/v4..._ddr284434.png
http://img.photobucket.com/albums/v4...72/xeon3-2.png
http://img.photobucket.com/albums/v4...72/xeon3-1.png
http://img.photobucket.com/albums/v4...nt72/xeon3.png
AM3 at 704/851 on 7900GTO, stock cooler (3.8GHz, DDR2-845 4-4-3-4, 2.28v)
http://img.photobucket.com/albums/v4...2/am3_176k.png
Hmm. I just had my Dominator 8500 memory die on my XBX2 as well. :( I had upped my VMCH up to 1.6 to try and get the memory to run at its rated 1066 speeds and I noticed I started to get a lot of mem related errors in Windows. Setting things back to slower 533 speeds, I was still getting errors in Memtest. It looks like one of my four 1GB modules is shot.Quote:
Originally Posted by ChaosMinionX
Hm, so I seem to be erroring quite a bit on test #7 on memtest86+
Running 389x9 at 4:5 with Corsair XMS2 DDR800 at 5-5-5-18 @ 2.2vcore.
Are there any other settings besides upping the vcore that would help stabilizing this RAM? vfsb? vmch?
BX2 has been rock solid since I put it in. ;)
EDIT: Well I just dropped it to a 1:1 memory divider with 4-4-4-12 timing @ 2.0vcore. Performance seems a little worse but it's stable. Guess this RAM just can't handle that high of speed. I was always told Intels prefer frequency rather than timing (hence the reason I was trying for a high latency with loose timing setup).
EDIT: Well, what the hell. It's erroring on stock timing of 5-5-5-18...
I get that same problem with my teamgroup sticks (see sig for specs).Quote:
Originally Posted by Eluzion
I even RMA'd my first XBX2 because I couldn't overclock past 3.4GHz without getting frequent and debilitating memory errors, even with the looses timings and highest rated voltages. It was so unstable I could barely keep my system on long enough to determine it was in fact the memory that was failing.
Here I am now, new board, newest bios, and identical problem. (Yes I have tried older BIOS versions; the memory errors persist.) I just run mine at 379x9 (3.4 GHz) with 1:1 mem settings @ 379.5 MHz, 4-3-3-9, which has kept stable for me.
I intend to swap these sticks, the tankguys.biz guys are pretty cool, but I can't be bothered just yet.
Just letting you know you aren't alone.
It work :banana:Quote:
Originally Posted by Suge Knight
http://sugeknight.info/PC/Cartes%20m...200-102-33.png
I make a point of thanking the SETFSB team for their quick answers end their work. :clap:
sad sad news! My Storm G5 won't make solid contact with my cpu due to the caps being too high. My load temps skyrocketed to 83 while idle was like 47 at 3.75ghz 1.45vcore. Its a solid board too. Anyone else have waterblock mounting issues?
