Watch out for clogging...
Is there much difference in heat output versus air cooling? Currently, i have one 80mm intake fan, 120mm CPU fan (ThermalTake Blue Orb 2), and 120mm exhaust fan. The room this computer is in is 10'x12', and it heats up the room to the point that i am on the verge of sweating. Does watercooling decrease in heat output? My reasoning behind the thought that it would is that with watercooling, you have only 1 120mm (depending. i've always been looking at dual 120mm rads for my WC ideas).
BTW, I figured this would be the best place to ask before making a thread.
Heat outputted by the components doesent change, its just more efficient at dissipating it.
Well, you have to add 1-2 fans's worth of heat (9-15w typically) for the pump.
:rolleyes: Very nice! :toast:
http://www.4eweb.de/pc/blackmaster/26.jpg[/QUOTE]
Nice and clean! :woot: :toast: :clap:
*even though nothing is plugged in*
Am I the only one who finds that radiator grille hideous/super restrictive?
no.Quote:
Originally Posted by majestik
no, i was going to say the same thing till i saw ur replyQuote:
Aluminum!!!! Run! :o
Is that an alu block on the gpu? :(Quote:
Originally Posted by Grinch
*pukes*
How come they're not connected? Mobo power,Hard drives and Optical drive :stick:Quote:
Originally Posted by krueml
double post
http://i20.photobucket.com/albums/b2...0/IMG_1399.jpg
http://i20.photobucket.com/albums/b2...0/IMG_1398.jpg
AquaXtreme MP-05
Swiftech MCW60
DDC+Radiical Top
PA120.1
Yate Loons
is it the tank wich is in the top of the case? seemes like alot of un neccesery tubing...
There's even a smiley for that... :sick:Quote:
Originally Posted by creidiki
:lol:
could be better if you put the tank on the lowest bay slot. and put a little lighting so everything stands out. anyways, thats just me. :toast:Quote:
Originally Posted by Pied
Very nice! :)
I would put the res in the 3rd slot (counting from top).
Very dark pics btw...
heh, i don't want to bling bling crap. just wanted a nice and clean setup.
I like the rez kind of hidden. maybe i'll move it down a bit
Comrades, rebel against the bling burguoise! Viva la revolucion! o7
Agree... I try to lay low on the bling. Although I don't know if people consider my rig too bling-y. White cathodes and stock Voodoo bling, but not a whole lot of additional aftermarket bling. ;)
i single backlighting positioned the right way would do wonders for that dark case interior...
Nice lighting. The small tubing makes me cry, but oh well.
