@closetredneck - Your 840 looks great. However, have you considered re looping you loops? the tubes looks messy.
Very nice build scamps, clean and great looking!
Finished my new build, not as clean looking as some of the builds in this thread, but I'm satisfied :yepp:
Hardware:
P6tD Deluxe
i7 920
G.Skill Tridents
2x5770
Crucial 64GB SSD
WD 320GB
Corsair HX580W
Watercooling:
HK 3.0
mcr320
3x120(20mm) yates up top-pull, 1 yate 120 (20mm) & scythe 120 (12mm) - push
mcp350+xspc res
http://i977.photobucket.com/albums/a...x/PICT1137.jpg
I have, actually. One of the things I was considering was placing the fans above the top radiator, pulling cool air in and pushing it through the radiator. This would require me to rotate the radiator 180* so the bend to the reservoir would not be too tight. If I did this, the fittings on the radiator would be at the rear of the case.
Also, the long runs are somewhat necessary since the res/pumps are in the drive bay. In addition, I had to make them a little longer to provide enough slack to pull the res out of the front of the bay for fill/drain.
I'm always open to suggestions.... If you have any, please post them in my worklog. The link is in my sig. :up: Thanks!
anthony8659
Whats the LCD
@waterflex
samsung 2253
Hi, I didn´t know if this is the right place to show my rig, so i´m sorry if i´m wrong.
There you go:
http://i49.tinypic.com/opsocj.jpg
http://i45.tinypic.com/nfmwbo.jpg
http://i46.tinypic.com/eumx04.jpg
http://i49.tinypic.com/14ayk1u.jpg
- eVGA P55 FTW
- i5 750
- 4 Gb Gskill Trident CL8
- XFX 5870
- Corsair H50
- X-Fi Xtreme Audio
- Seasonic M12 600W
Tell me 'bout that keyboard :)
Hello, Nice work all. My first time posting here, my second water cooled build.
Lian-Li PC-8n.
I still want to do a bit, just haven't figured it out yet. I also want to make some lighting changes.
http://i59.photobucket.com/albums/g2...IMG_0006-1.jpg
http://i59.photobucket.com/albums/g2...IMG_0007-1.jpg
http://i59.photobucket.com/albums/g2...IMG_0008-1.jpg
figure i'll throw mine in here, it's changed a bit since these pics, but not too too much, i'll post an update a bit later
http://img.techpowerup.org/100115/DSCF0981.jpg
http://img.techpowerup.org/100115/DSCF0982.jpg
http://img.techpowerup.org/100115/DSCF0983.jpg
http://img.techpowerup.org/100115/DSCF0984.jpg
and - 2 more photos via link, to comply with the 4 image limit ;)
http://img.techpowerup.org/100115/DSCF0996.jpg
http://img.techpowerup.org/100115/DSCF1014.jpg
This thread needs a really big broom taken to it. :yepp:
http://www.xtremesystems.org/forums/...96&postcount=1
Tell me about it - every couple days I wear my little fingers out editing posts. Still need to figure out a way to have the guidelines pop up regularly. I know folks don't mean to go against guidelines by posting more than four images / quoting pics / etc - they just don't understand.
To clarify - this thread is to show finished liquid-cooled systems. A maximum of four images, no quoting pics, and minimal discussion. These rules are here to keep the thread easy to use for people who want to look at systems and get ideas. PM discussions are encouraged. Work logs are encouraged if you want to share more.
I'll come back later to take care of the last couple of pages - lunch time now.
Thank YOU ;) And beautiful pics - great job on your build!Quote:
Should be four only
@Schlingel
Did you redo your loop a little bit? Maybe the color of the liquid?
Nice work. Nice photos too.
not finished yet... still have sleeving to do. also going to be swapping mobos when the new dual socket evga board comes out. will have everything on water.
http://www.techpowerup.com/reviews/M...shed_small.jpg http://www.techpowerup.com/reviews/M...hed1_small.jpg http://www.techpowerup.com/reviews/M...shed_small.jpg
http://www.techpowerup.com/reviews/M...hed5_small.jpg http://www.techpowerup.com/reviews/M...hed6_small.jpg
http://www.techpowerup.com/reviews/M...hed1_small.jpg http://www.techpowerup.com/reviews/M...hed2_small.jpg http://www.techpowerup.com/reviews/M...hed3_small.jpg http://www.techpowerup.com/reviews/M...hed4_small.jpg
Here's mine:
i7 860
ASUS Maximus III Formula
8GB Corsair Dominator DDR3 1600
ATi 5970 | NZXT Khaos Case
Corsair 1000w PSU
Swiftech H20 Cooling CPU
Windows 7 x64
http://i282.photobucket.com/albums/k...g?t=1262486687
http://i282.photobucket.com/albums/k...g?t=1263954304
http://i282.photobucket.com/albums/k...g?t=1263954124
http://i282.photobucket.com/albums/k...g?t=1264387783
Beautiful, fitseries. Thanks for using the thumbnails to show us more than 4 images.
Waymon - nice setup. Please edit your post to include only 4 images - use links or thumbnails if you would like to include more.
*** nag mode off ***
