Originally Posted by Formann
EDIT:
Tried to run 100Mhz on RAM, and suddenly I was able to run super-pi at 2920Mhz. 265/270HTT is max with divider (except 100Mhz)
Diddn´t tink the MSI would give me problems at sub 310-320HTT. crap.. :(
EDIT:
// link removed.
Hi Guys,
I wish to get a VCore of 1.8 with a Winni on the MSI Neo 2 plat. I have phase change cooling - 47.5 so i feel this is safe. But when I apply this voltage with core centre it gives me 1.7, when I apply 1.85 in Core Centre I get 1.75 I need about 1.8 volts. With the winni how do I do this?
http://www.xtremesystems.org/forums/...8&goto=newpostQuote:
Originally Posted by pazza316
Jep i finally got 1 second of from my record and 5 seconds from my 8m record :cool: superpi1m_32s...superpi8m_5m54s but i hope i can go under 20seconds in pifast pifast..
Got tired of running my 3200+ winnies. This crappy MSI wont run RAM dividers over 260-265HTT. So I installed my old 3500+ NewCastle and put it under the r404a cooler Overklokk built for me :)
Super-pi 1M - 28sek
A64 3500+ NC @ 2950Mhz - 268*11
Twinmos BH5 @ 268 2-2-2-5 (codered tweaked)
Crappy 2000 install..
Max super-pi stable speed is 273*11. Dont know if its the CPU or the memcontroller stopping me. Maybe ill try max CPU speed with 100Mhz div on RAM.
that's right about the dividers with some types of memory. My Twinmos SP didn't divide either, so i got stuck at 10x250 so that sucked big time! But kingston hyperx (BH5) for example, is dividable.
and the producing week was...?Quote:
Originally Posted by Digg
0450 VPEWQuote:
Originally Posted by daysleeper
DFi nf3 250 gb
2x512 OCZ Plat Rev 2 Pc3200
R.S. all day
http://img240.exs.cx/img240/3995/27008vi.jpg
http://img205.exs.cx/img205/3174/2700mem1uj.jpg
http://img212.exs.cx/img212/1356/misto1de.jpg
:banana:
hey Giasan...already saw that screen....
:toast:
Originally Posted by CapFTP
Hi Cap, i know :D :D
http://users.pandora.be/dajefn/pc/ov...ng/2763MHz.JPG
CBBHD 0450WPBW boxed cooler
stable at 9x300 1.6V (200MHz 2.5-2-2-5) all day long D2OL
is that normaly?
http://www.crmk.de/400FsbRock.jpg
is that normaly?
http://www.crmk.de/400FsbRock.JPG
Install version 1.26.
It is amazing to get 2.8 with 3000 since that is 1 GHz overclock but you should get some better memory with that. I get better superpi than this with 150 MHz lower clocked processor. Your superpi is rather bad given the clock. Needs to be at least 1 minute faster, or better.Quote:
Originally Posted by Crmk
DTR 3000+ CAAZC 0501 DPMW. Still working on it, but 2700mhz at 1.68v is not to shabby for a clawhammer.
http://home.comcast.net/~jhatfie/superpi_32M_2700.jpg
No, 1.27 :DQuote:
Originally Posted by L0$t Pr0PhEt
is there anyone who using AMD athlon 64 3000+(winchester)0,09 nm :cool:
+89% :banana: 4800+ Frequency :D
http://pageperso.aol.fr/misteroadster/3405.JPG
Really impressive! :slobber:
Cooling?Temps?Vcore Mod?
A64 3000+ 0450 WPBW On Air Unfortunately my motherboard is completely unstable with fsb330 and higher :( With Clockgen i can push it up to 3070Mhz Im still waiting for my DFI...
http://members.lycos.co.uk/obligator/3.0Ghzs.JPG
Winny 3200+ CBBHD 0450RPAW @ 2776Mhz 1.7V
cpuid validation:
http://valid.x86-secret.com/show_oc?id=2819
http://img41.exs.cx/img41/56/2778dl.jpg
Can go more but not stable and no pi can be calculated
http://valid.x86-secret.com/show_oc?id=2820
http://valid.x86-secret.com/cache/2820.png
