I would say 20-40% depending on how much I am on the phone with the customers. As I also test our own applications to make sure everything comes over.
Favorite juice? ie: apple, cranberry, orange, etc.
Pink Grapefruit w/ vodka :up:
In a set of movies what is #4 called after the trilogy?
A sequel?
Would you trade your HD4870x2 for two HD4870s? (assuming you had one)
Hells no!
Quake 2, eh? Gads I feel old now. I used to play Zenith and Mystery House on the Apple IIe when they were current releases.
Do you understand the Star Trek rule of Evens?
E2140 @ 3.2GHz, 3x2GB DDR2 800, HD3850-256, WD 320GB+1TB drives, Vista HP64.
How should I spend $684? Mind you I need a new phone too.
Mine is something i got off interfacelift.com, its a few trees in black and white. (I enjoy simplicity on my desktop) I change it around once a month.
How did you come up with your username?
I just looked around and it seems like a job that you shouldn't do by yourself unless you're a qualified electrician. Estimates range from $2,000 to $3,000. I don't own a house though so somebody with more knowledge should probably elaborate.
What should I do with my watercooling setup? I threw away my reservoir yesterday because I couldn't open it to get to the algea on the insides of it. Now I'm stuck with a Thermochill PA120.2, some Tygon R3400 which I tried cleaning a bit with pipe cleaners, a DD MC-TDX that would desperately need cleaning on the insides but I can't do that without voiding the warranty. I also have a pump, a Laing DDC-1T. Should I sell it all? I'm a bit fed up with the maintenance needed to be honest, and a good air cooling set up is only as loud as the fans on it and the same goes for a water cooling set up.
This is what I am using on my water cooled crunchers.
http://i138.photobucket.com/albums/q...t/DSCF0562.jpg http://i138.photobucket.com/albums/q...t/DSCF0561.jpghttp://i138.photobucket.com/albums/q...t/DSCF0560.jpg
But ask over in the water cooling as I am not 100% sure its ok. Its good enough for a radiator so it must be alright.
Do you have more than 2 i7s crunching atm?
No, I have one i7 at home, Athlon XP at home and C2D X6800 at work.
What productivity application is running on your main PC most often?
Pr0n. :rofl:
Good day! What's your current local time?
7:39PM :)
Want to hazard a guess when the new Seagate Momentus 7200.4 will be in stock? They've been listed for ages now and I need a 500GB 7200RPM drive for my laptop quite badly now :rolleyes:
A Icanhascheezeburger book. http://icanhascheezburger.com/
how many tabs do you have open right now?
3, but I had 7 a few minutes ago.
Have you ever tried to get your fancy new phone to crunch?
No I have not I have a razor but I am pretty sure it wont crunch.
Favorite thing to play with at your place of work?
If you mean "at the place where I work" - liquid nitrogen :D
If you mean "which belongs to your workplace" - single stage, one of my favourite motherboards and any CPU :)
Do you work in your area of expertise? If not, have you ever?
Still studying but theory in on-the-job learning course i did.
What happened to this thread?
Btw, I curse that xoqolatl's avatar to lowest hell! Killed my concentration many times when that 7 changed to 8 :ROTF:
This thread got forgotten when common suspects ran out of good questions.
@ s0lid: I might remake this avatar with longer interval between eights, that would be even more annoying :D
Did you donate to XtremeSystems?
Nope i didn't, no cash to spend and well i can already change my user title :P
What you think about my latest investmet?
Sure I do, as long as rich people exists, they will come with their boats to the harbour i work. They will be less germans and more russians, though.
Do you play any sort of musical instrument?
yup, a trumpet.
(And welcome to the forums)
Prava, are you on the XS WCG team?
