Try a IDE DVDRW and JUST that on the cable with the DVDRW set to master
the dvdrw is IDE.. I ended up installing from a USB HDD as a solution to the IDE dvdrw not being seen :shrug:
i'm going to check jumper... if that fails I may have damaged the cable during installation - i admittedly was rough with the cable to route it thru a hole I wanted it to go :yawn:
I think its P04 :)
sorry for image size :(
yup, thats the right one..just checked, same as mine.
:rofl: you get days like that.
the other problem I have is: one cpu is ~42C, the other 70C :eek: :shrug:
is this normal? is that an error in the reading? or have I not mounted the HSs properly? :(
I'm using CPUID Hardware Monitor 1.16.0
I'd check that heat sink mount, pronto. Make sure you remembered to a - screw it down, b - put some TIM in there and c - turned the little locking doo-dat in the CPU socket all the way to the "lock" position.
No matter how fine the surface looks, there are always pits scratches bumps and hollows. I'd guess that the hot one is more so than the other, but the difference could be only microns or it could be a tiny burr that's become the only point of contact. Regardless, you need TIM for a reliable thermal interface.
Did you remount the HS with some decent TIM?
Maybe. The thermal shutdown relies on logic reading the internal registers, not a calibrated temperature switch and even then there's no way of knowing how good the protection actually is. Some chips can fry themselves before the protection can react.
Just stop installing programs and shut it off and get some TIM on there. Even some Arctic 5 will work too! You're going to fry it. What a waste.
:sofa:
ok.. I did it.. temps: CPU1: ~40C, CPU2: ~32C
:D :D :D *runs & hides*
Nice work Tiro. I burnt up a CPU and a mobo like that before.
A little trick I learned the hard way years ago.
Whenever I build a new system when I'm done but before firing up I get up, walk away,grab a coke,coffee,etc take a few mins away from the system and then come back and physically touch and check every connection.
Visually inspect everything.. Takes maybe an additional 3 minutes but you'd be surprised at how often you find something thats loose and generally loose from after you'd connected it but loosened it with a hand that was working on another connector.
Just makes for a good final check and has saved my butt many times.
:sofa:
*shy voice*: permission to come aboard captain?
;) ;) :yepp:
