you should be able to hit 1100mhz+ with 2-2.1v
with my redline 2.03v=1130mhz
Many thanks for the advice. Are you sure the HR-09 doesn't fit? This Thermalright page seems to indicate that it does.
Also, I wasn't actually going to put water through the Flex II, I just liked the PC2-9200 rating. I'll check out those G-Skills. I've also heard recommendations for Corsair Dominators in this thread. I guess this board isn't too picky with memory.
all of those kits are the same just different heat spreaders but they are all powerchips so they dont go hot in the 1st place, and TR says it works it dose but it looks questionable to me
http://www.petrastechshop.com/thhrsmocot2u.html , if u look at the diagram its offset push pins so i would be hesitant
dose any1 know if u can get the hard mounting plate for the hr-09 near the IO panel that the UT boards have to use the LT, and is there any chance of getting one
hopefully some1 like praz can help with this
http://i26.tinypic.com/2dme4k2.jpg
it looks non attached and a support piece
anyway i can delete entries in CMOS reloaded
or is my only option to overwrite them
@Praz: have you tried replacing the TIM under the Transpiper?
Has anyone with a 45nm tried setting "host slew rate" to strong? Anandtech claims that setting helps with 45nm processors.
does anyone have working download links for DFI WinReload? I need both vista and xp.
Download link for Win Reloaded for XP. Don't believe there is a publicly available version for Vista.
Win Reloaded
Hello guys, just got my system together (x48 LT, 4gb 1066 ram, 850w antec, e8500). I have a few questions for you pros. How do I get the 9.5 multi? Alos, can someone please post what I should try for a base line (what volts for what and what needs to be on and off) and what bios? This is my frist DFI board and I'm trying to do this on my own. Oh, I'm on phase too. Thanks.
I can't get my G.Skill 4GB DDR2 PK PC2-8500C5 to boot using the 333/800 strap works fine with the 333/1066 :confused: Using DFI LanParty LT X48-T2R and E8500 everything at stock, just cant get it to load windows. It get as far as the WinXP startup sound and then freezes making a screeching sound. I had this problem with the 333/1066 strap, but it worked in the end, but not this time I have removed the card and yet it still won't boot :( Not sure if this is memory or motherboard :confused:
Anyone else got this board and memory did you mange to get it working at the 333/800 :confused: If so any chance of posting your setting? I'm noob at this so might be a simple setting I have wrong............I hope.
Can someone please post their settings for UT X48-T2R and Q9450?
Also some idle/load temps for the chipset.
Please can somebody post the settings with q6600?? (step by step please...) thank you!!!
Just put in a pair of 4850s tonight, it's working so far. So far it's a bit of hit and miss compared to my 8800GTX (guess I better change the sig). In Crysis, I've seen onetest say 4850CF did better than a single 4850, I've seen one test say it's the same speed, and in my case so far, I get worse speed when I run them in CF instead of a single unit. The single 4850 gets about the same FPS as my 8800GTX. In the Devil May Cry 4 demo and in COD4 multi-player, I'm getting double the FPS in Crossfire than what my 8800GTX did.
Noise wise I'm getting a weird harmonic from them, and they're probably louder than my 8800GTX at load. Heat wise, my system seems to be about 2 degrees warmer at idle, add another degree or two at load. Definately can't wait to watercool these. If I keep em. I expect I will, unless I see a bargain I can't miss, but all things considered, I don't see the 280 dropping below $500 anytime soon.
Which slots are you running the 4850's in? (1-2, 1-3 or 2-3)
Thought of buying UT T2R soon, so which combination of GFX would be the best?
3 x 4850 or 2 x 4870?
