Originally Posted by
thelawns
Hmmm, seeing as I have had no response to my last post on p63 i'll try to break it down a bit...
I have just updated my system slightly this week to include this Maximus Formula SE board, which is a 1.02g revision. Spec as follows:
Processor: C2D E6550 2.33ghz FSB1333 4mb
Memory: Kingston Hyper-X 2gb(2x1gb) 800mhz Low Latency 4-4-4-12 KHX6400D2LLK2/2G
Graphics: XFX 8800GTS 640mb
Sound: Auzentech X-Fi Prelude (in PCI slot above graphics card)
Case: Antec P182 SE
Power: Antec Neo HE 650w Blue
Drives: 2x 36gb Raptors, 1x 320mb Seagate 3gbSATA, 1x Sony SATA DVDRW
Now, its all setup and working. I have a Win XP Pro SP1 installation disk.
Despite using the Makedisk option(on another PC) so I could RAID0 my Raptors, XP setup was having none of it and kept rejecting the disk saying it couldn't create some sort of OEM file? In the end I have installed XP Pro on just one of the Raptors and I am using the other as the 'My Documents' disk. This is not ideally how I wanted it though of course.
Once I had everything installed and all the latest updates(SP2 etc) and antivirus installed I ran the 3dMark06 prog and got a score. Everything was fine and dandy.
Using the AI Suite I ran the auto system test button in the Gearbox area and then ran 3Dmark while using the Auto overclock option, which gave me about 400 extra on the score. I tried the Turbo option and this was slightly less than the Auto option. I then decided to start changing the multiplier in the manual overclock section. This was set at x7 so I simply changed it to x8 and rebooted. But it didn't reboot and the overclock failed. Fine, I thought I'd leave this manual overclocking alone for now and set about putting it on the Auto overclock option again. Now, every time I change it to that setting or re-run the system test for that option I get a BSOD. I did have Kingston KVR 667mhz memory in the system but I have just changed it yesterday to the Hyper-X 800mhz but it makes no difference, I still get the BSOD. Win32.sys seems to be the problem.
I have tried to clear the CMOS using the button at the back but I am not sure if that actually clears it? Have I corrupte my install and should I do a clean XP install, again? Have I broken something, namely my processor? If so I'll get it RMA'd asap?!?
I have now flashed to the latest official bios from the Asus webpage, 0602. Still same BSOD when changing the above settings.
Also, I am guessing its best to manually enter the timings for my memory in to the Bios as 4-4-4-12, as its showing up in grey as 5-5-5-15 on the Auto option??
Should I remove the black covers from the fusion block or not?
Lastly, every time I reboot my system since the above happened, the Wave volume is slid all the way to the bottom and the volume is Muted??
All help is greatly appreciated...
