Thank you. I am "playing" with the GTL settings a lot, trying to find something good to be Prime stable. I am using Orthos Blend test ;). What version of Prime95 do you suggest me? My OS is Vista Ultimate 32.
I read you post here http://www.xtremesystems.org/forums/....php?t=155373: your consideration were rellay heplfull for me, this one in particular: use rmclock to disable tm1, tm2, and extended throttling. if you don't do this, the multiplier will drop down to 6x if you go somewhere in the 80C range.
Thank you for answering, sorry for beening so late but I was busy.
1) I know that this motherboard drops a lot on voltages, so I am trying to use proper voltages.
2) Probably I will go back to the eVga, but I wanna try again to make this DFI work, and I hope that a better BIOS will be relased.
3) I know that all the chips are different, and probably the one that I have on this moteherboard in the NB is not so good.
4) The fact is that I have problems in booting only using the 2CTST BIOS... With the other BIOS is it not a problem to boot and to run 400Mhz FSB, I have temperature problmes in that case. I will try to change CPU and to thake a G0, I will also try a Phase cooling system. I am sure that the 400+ FSB will not be a problem.
I really think that my problem is BIOS-related. If I could set 6x multi on the 4CTST I am sure that it would be fine to make the system stable @ 400Mhz FSB or more. I will see what it is going to happen when the new CPU G0 and the new cooling system will arrive.
