Originally Posted by SPL15
In my case nope.
2507 is the most stable for me. 2330 and 2333 were not stable for me.
2507 and 2496 seam to be comparable, but 2507 seams to be more stable after several days of being on running folding or prime. 2495 would give me a random reboot after being on a for about 12 to 15 hours 2507 has fixed that for me.
After all my issues and stuff, I'm fully 100% rock solid several days of orthos stable at 413Mhz FSB on a E6600 which runs about 3.713Ghz. 4 GB of Crucial Ram running 1:1 which is DDR826 @ 4,4,4,10 with 2.24 Volts. I've been running Dual Prime95 for a week straight and no more degradation.
BIOS settings I've found to matter are:
C1E - Disabled
Watchdog - Disabled ( see explanation below why this WONT WORK!!)
Debug - Disabled
PCI Bus Latency - 64 (seams to help with USB devices and HDTV card lockups)
PCI express burn in - 101.x (seams to have helped lockups during games over default, anything higher than 101 gives me lockups)
Vmch - 1.7v actual from Vmod (I think I just have a weak and wussy 925X)
Vfsb - 1.425v (Helped with stability although I'm still testing this)
VT - enable (computer seams more stable after enabling even though it should have NOTHING to do with stability... maybe its my wussy chipset)
Vmem - 2.24 (usual stuff here nothing new)
Vcore - 1.45 (1.400 actual measured usual stuff here)
For the stupid "watchdog" setting on the XBX2, it will not work correctly on anything needing slightly hot voltage for the CPU WHY?? Well the XBX2, like most motherboards, has an initial powerup Vcore voltage that is per Intel specification of 1.1xx volts. Well if your CPU needs 1.45 volts to be stable at a certain overclock, then 1.1xx volts aint gonna get it stable enough to post correctly so the CPU clock will not be clocking and the watchdog will not get it's clock signal so the watchdog timer (thats on any commercially available computer circuit made by mankind) will pulse the reset line, by now the motherboard has given the CPU the higher VID voltage or cmos programmed Vcore voltage and now posts.
The intel "watchdog" is basically monitoring whether the watchdog is firing during post, if it fires, then it assumes that you have a poor overclock and gives you that stupid error. Watchdog timers are on any and every motherboard ever made by mankind and any and every embedded CPU, microcontroller, PIC, etc. It is nothing more than a system that watches for a clock signal and if it stops for a time length, it fires a reset signal in hopes of restarting the clock signal.
Using the watchdog "feature" on the XBX2 will limit your overclocks to a low enough setting that still enables the CPU to initially clock correctly at 1.1xx volts thus avoiding the watchdog from firing.
On other motherboards (p5b comes to mind) some people have problems with their system not posting until they hit reset. In this case, you are actually acting as a "watchdog timer". You physically see that there is no post which means there is no clock so you pulse the reset line and then things work because by the time you push the reset line, the Vcore is up where it needs to be in order to post.
Basically on the XBX2, the watchdog is a feature when it is disabled in the BIOS because the disabled setting allows the watchdog to reset the computer and give it another shot at posting when Vcore is higher, which is how a watchdog circuit should work in the first place. This concept unfortunately is not something new and has been around since before I was a fetus. Intel's watchdog setting basically tells you that the watchdog timer has fired a reset signal during post which means that the CPU isnt stable at the specified 1.1xx volts intial startup voltage. I basically see it as a way for Intel to limit Overclocking for a huge majority of casual overclockers / enthusiasts, thus making them want to upgrade to a better CPU in the future.
