need help with two dvd burners on this mobo
Hi All,
This is my first post but I have been reading this forum for awhile. I have two memorex dvd-burners when I run them on the same ide cable I get problems regardless how jumpers are set. In bios there are seen properly as primary and slave but in windows one drive just freezes the computer and if I try to copy a disk from a to b I get error messages. Anyone out there that can help ? The only way to get both drives to work is to hook up one to the ide cable and the other to the eide on the bottom middle of the mobo which is a huge pain.
e6600
p5w dh mobo (1503 bios)
ati x1950xtx
pny verto 1 gb pc2-6400 800 mhz 44484 2.1 volts
2 memorex dvd-burners
lan-boy antec case
700w power supply
2 raptors 74gb running raid 0 config
Few pics of my rig below the last picture is the problem child drives
http://imageigloo.com/thumbs/7215DSC01256.JPGhttp://imageigloo.com/thumbs/1665DSC01253.JPG
http://imageigloo.com/thumbs/6392DSC01262.JPG
http://imageigloo.com/thumbs/3309DSC01270.JPG
CMOS reset needed almost every reboot
Hi all.
This is my first post, and first of all, I would like to thank everyone who has made contributions to this thread.
I am not a native english speaker, so I apologize in advance for my errors.
Iīve been reading a lot on this thread before this post.
I have one big issue with this mobo: sometimes after a reboot or shutdown, the screen simply does not get any signal from the video card, and doesnīt matter what I try (power-off - press shutdown button for more than 5 secs; turn-off the psu; soft reboot - ctrl+alt+del; ...) the mobo wonīt post anymore.
The only way to boot or post again is taking the CMOS battery (and the Radeon, to get to the battery) off the mobo, and reset the CMOS (as described by the mobo manual).
This happens even in stock settings.
It has happened using BIOS releases 1101, 1305 (the most stable), 1401, 1402, 1407, 1501 and 1502.
I was wondering if this has not to do with a bug within energy saving BIOS features (that I just canīt disable anyhow)...
I just canīt stand anymore to reset the CMOS everytime I need to reboot...
Thatīs why I want do ask my question:
Do you think that the rebootbug (1503 fix) can fix this too?
