I'm at box cooling. It hits 60 with 1,45 v full load.Quote:
well that's pretty warm isn't it. I've heard of cores failing once they get above 54c or so.
Are you planning on attaching that nice Vapochill up to it?
Yes it's cind of hot, bot I'm running the stock AMD cooling paste :rolleyes:Quote:
I'll try to change it to some AS5 and add some airflow to my case and see what it does.
I'll see if I get the time to mess around with the vapo this weekend, otherwise I could do it on monday.
BTW, just ordered another x2 3800+ - Hoping for another LDBHE 0601 UPMW
Thank you to Mario Bros - you made me reinstall my watercooling completely, and remove one of my two rads (dual heatercore and 120.2 copper Rad). Now that there is not as much flow restriction and I have shortened all piping etc, I now dual prime load 1.50v 11x255 = 2805mhz @ 38-40C :D. At my previous clock which was 39 on 1.36v and 2600mhz, I now am down 5C to 34C. Excellent temps all round, allowing me to push harder. So, thank you very much :D.Quote:
Originally Posted by Mari0-Br0s
Here my first dualcore. Its not nice but its ok. Its a tpmw 0601 with 82* batch.
http://www.forumdeluxx.de/gallery/da..._5_Stunden.JPG
http://www.forumdeluxx.de/gallery/da..._7_Stunden.JPG
Just got this running today. My first AMD.
Athlon 64 X2
ADA3800DAA5BV
LDBHE 0605GPMW
Am I the only one who have a really hard time getting my temps down?
When dual priming the temp is around 60 :( And this is at 1,36 V. :stick:
I have tried changing the thermal paste, but it didn't help.
I'm running on stock cooling...
New clock from what I had before:
CPU-Z validated
X2 4400+ CCBWE 0546SPAW @ 2805mhz (11x255) 1.49V
http://www.diduknow.co.uk/dual%20pri...0validated.PNG
:D Dual prime loaded @ 42C custom watercooled - Swiftech MCW6002, AquaExtreme 50z, dual heatercore in push/pull config, Silverprop HL fusion (not connected up to graphics yet [X1800XT 512MB]).
Just mounted my vapochill (damn I have missed the sound of it :rolleyes: ), and it's running about 10 C to 12 C full load at dual prime with 1,36 V.Quote:
Also just resived a LDBHE 0601 TPWM, and it have even bigger heat issues, it ran 65 C at dual prime on stock cooler :confused:
I'll be posting some results later today :p:
Would you buy an X2 3800+ 0605 TPMW?:confused:
Here are the first results. Know it isn't much valid, but will post some more valid results later :)
BTW how do you enable the time function, so you can see for how long i prime have run??
http://i10.photobucket.com/albums/a1...uicktestII.jpg
you want to use sp2004 for that.
Anyway im back on my CPU (finally!!) currently priming at 2.1ghz. Smartguardian reports a nice 17c temps, with stock votls and 2.1ghz. Since im in an ambient of 10c and using a 120.3 for just the cpu (x1800xt on air at the mo) it's pretty good.
Now no flaming for not being a long time, or because it's a low priority.
But here's where i am at the moment - looking like quite a nice chip. Please note, haven't tried any higher. And only been playing with this for about 4 hours.
http://img418.imageshack.us/img418/2...hzstock1tl.jpg
[QUOTE=don_vercetti]Now no flaming for not being a long time, or because it's a low priority.
Don, is your chip an N or T chip?
N. Is that good or bad?
it completed 2.6ghz for an hour, so i upped to 2.7ghz, core 0 died after 1m 13s. Time to start the voltage increasing process!
I think it's good. The one I got this morning is an N chip. tpmw 0601 3800. Not golden but no dog for dogsx2.;)Quote:
:) . LDBHE? How is it clocking then? What tcase specs do you get?
my 3800 that i got to about 2.8 on air core 1 unstable prime
CCBWE 0545RPMW is this a good stepping?
Has anyone seen or had a recent CDBHE. I just got an 0607TPMW (X2~3800+), today; was expecting an LDBHE, but saw the BH and figured what the heck, I'll give it a shot. Was wondering what other folks have done with this stepping. Waiting on cooling, should be here tomorrow.
It's a kind of weird CPU. It primes at 2950 MHz and 1,378 V for a few hours, but as soon as I bumps it up to 3000 MHz It crashes emidiatly. :confused:
And BTW I crashed my windows, so have to reinstall before I can test futher :(
I hope to get it tested fully this weekend, and also get to test my TPMW stepping...
im guessing ur on phase for that kind of OC?
Yep, a small stock vapochill SE :stick: Gonna try to bump up the voltage later today.Quote:
Originally Posted by KViper19
Anyone has got some GOOD Pics from a "x2 3800+ Manchester Core" without IHS ?! If so, it would be nice to get some pics in original size or bigger!
Perhaps I will take off the ihs from the manchester I will get this weekend.
im thinking about popping the IHS on my 3800 for my nwe watercooling, but i have a dud toledo not manchester
another 3800 is on the way, canceled my 126 order lol! I love these things. once i get my sli-dr board thats replacing my ultra-d im gonna install my old or new 3800 not sure,install watercooling, get a new windows serial because my other board died, then gonna install the hotfix and dual copre patch for quake 4. If i use my old one illl get to mad overclocking first thing if new ill burn in then oc mad.
