5.1 ghz on a 930D? with that cooling shown in your signature???
that's absolutely impossible...
even with a vapo it should not be an easy task... 930D produce some massive heat, compared to a C2D...
somebody can tell me the WR with air cooling with E4300 :up:
"5.1 ghz on a 930D? with that cooling shown in your signature???
even with a vapo it should not be an easy task... 930D produce some massive heat, compared to a C2D... "
Impossible or not,i did it. http://valid.x86-secret.com/show_oc?id=212353
Maybe i will reach higher, i dont know what is making problems @the moment, may be a FSB-wall @340FSB or the Ram.
The Board is only modded with the Droop-Mod with 50K. The voltages are Ram 2,0V ; CPU 1,5V (overvolted to 1,6V) , the rest is Auto, i didnt find a positive aspect if i change them manually. Maybe someone has a few tipps about that.....
PS: OcInside`s Hitman because im the Hitman of the German-OcInside-Forum. http://www.forum-inside.de/cgi-bin/f...&member=Hitman
PPS: A few Mhz more now. http://valid.x86-secret.com/show_oc?id=213074 Now 5181Mhz. Maybe reach with better cooling than water and chiller. But i wont use a comp or DI or N to cool it ;) .
PPPS: Ok hit 5200Mhz. http://valid.x86-secret.com/show_oc?id=213087
Some 930s are real good clockers. Mine was 5.2GHz on water, 5.6GHz on phase and 5.9GHz on DI. Actually, check the first post in this thread, mine is still there for the 930 record, but I am sure there's been faster now.
good joke :D 4ghz to go: http://valid.x86-secret.com/show_oc?id=182607
old school pooowwaaaa :D
WR 2200+ ?
AXMH2200FQQ3C AIUHB 0327 TPJW
http://maxicrash.free.fr/2200+%20M/DSCF5085.jpg
2.2v
NF7-S V2.0
2x256Mo BH5
2 stage Cascade by Skirms_fr
http://valid.x86-secret.com/show_oc.php?id=215277
http://valid.x86-secret.com/cache/215277.png
Pentium D 915 2.8 GHz - Todda7 - 5011MHZ - http://valid.x86-secret.com/show_oc?id=198243
http://img411.imageshack.us/img411/4...edigertxp9.jpg
Cpu on water, did the same CPU at 4.96 GHZ on AIR:D
http://www.diskusjon.no/index.php?ac...post&id=142451
Mobile Sempron 3000+ LV (Roma core)@2610Mhz http://valid.x86-secret.com/show_oc.php?id=230319
Running 24/7 and prime stable for 12h+
Cpu-z detects it as albany core (witch is a mobile a64 core)
The only Mobile Sempron 3000 listed on first page is Sonora core
EDIT: Can go higher, but not stable.
http://valid.x86-secret.com/show_oc.php?id=230338
Have done around 320x8 but got no cpu-z on that, really not interested in clock without 100% stability :p
How the hell did someone go over 3Ghz with a Clawhammer, the highest I can get my socket 754 3700+ is 2.586 and once it blue screened, I got it to 2.6Ghz once but after a few minutes I got the BSOD, is there a really good guide for overclocking these clawhammers, I've heard clawhammers aren't that great for oc'ing anyways, I hope I have better luck when my Zalman CNPS9700 LED comes in :)
Celeron 420 @ 3776Mhz with Dry Ice
http://valid.x86-secret.com/show_oc.php?id=233887
Overcrash is on a killing spree here :D
I love the 2200+ WR by the way :D
http://valid.x86-secret.com/show_oc.php?id=231557
http://img46.imageshack.us/img46/2770/cpu3481hw0.png
and
http://valid.x86-secret.com/show_oc.php?id=231556
:D
All on regular water cooling (10-15C ambients) with some ice cubes in the res.
WR for Opteron 170. http://valid.x86-secret.com/show_oc.php?id=238914
3564.67 MHz
http://valid.x86-secret.com/show_oc.php?id=239197
Mines run eleven houres orthos stable..
That's not the WR, this is: http://valid.x86-secret.com/show_oc.php?id=206901
The new AM2s seem to be able to go past 3GHz much easier than last gen's.
ffs 150%~?
Did anyone see a higher oc of a E2140 somewhere?
http://valid.x86-secret.com/show_oc.php?id=248702
Opteron 180 WR
http://valid.x86-secret.com/show_oc.php?id=251442
First dice session:D The pot was badly mounted, which is why it didn't coldbug. However, when I gave it more than 1.55v it suddenly got very hot. I re-benched it with the pot, much better contact this time - but -40c on core1 was too cold to avoid the bug, so I could only try to get some otehr benchmark records.
