At least not in the back... :p:
well pray to the H20 gods that this weekend I can get my loop together, filled and leak testing, if so I will post pics in my stacker thread, then when i get the beast back together I will post a shot of it here.
I finally have all the components. YEAH!:woot: :toast:
I have a Stacker with the rad mouned in the top, works very well and there's alot of room left in the case. Need some work on the cables though. Can post pics later maybe. :)
something else? like what?Quote:
Originally Posted by k0nsl
you let your cat sleep in there or something?
Cat + Computer = BAD BAD BAD BAD BAD:nono: :slapass: :slap:Quote:
Originally Posted by CRXican
Some people aren't quiet so dB concerneed that's why the rad is out back on that Stacker.
Oh and i'd like to see you fit 2xPSU's, 4xIDE's, 4xSATA's, full pci slots, along with multicard readers, floppys, and 3 bays full of monitoring stuff (gatewatch, and my home made lcd panel with a switch).
I.E. The entire front bay is packed from top to bottom. And the tiny spare space you get between the smaller devices like floppies is crammed with cabling to try hide it.
Please look more closely at the picture before saying things like that, alot of reason's for many things. :)
Plus i like to think i have very minimized tubing / minimized kink's with the current orrientation of things.
Studio pix :p
just to finish it off.
http://img63.imageshack.us/img63/7606/dsc02640cu7.jpg
http://img79.imageshack.us/img79/7998/dsc02645yd1.jpg
Lan Li V2000
http://img122.imageshack.us/img122/7837/dscf0078iz4.jpg
http://img233.imageshack.us/img233/8...0078jl8.th.jpg http://img275.imageshack.us/img275/4...0095in2.th.jpg
http://img123.imageshack.us/img123/4...0084yk4.th.jpg http://img162.imageshack.us/img162/2...0091ss5.th.jpg
http://img359.imageshack.us/img359/5...0088ms6.th.jpg http://img71.imageshack.us/img71/244...0106kr7.th.jpg
Odd Pics
http://img454.imageshack.us/img454/9...0067cv9.th.jpg http://img455.imageshack.us/img455/4...0071bw0.th.jpg
Original Thread & Build Pictures Here
JME F1delity, amazing case :clap:. is the dragon on the side a sticker or what is it?
Yeah, looks great JME! What case is that? Some sort of an LL case?
well, got my new intel system (p d 805 ....)
so i thought wtf y not, i also updated my rad from my heater core, from a liquid cooled minibike or something, got it from a friend
http://img421.imageshack.us/img421/3...0002tj0.th.jpghttp://img391.imageshack.us/img391/1...0004ry6.th.jpg
http://img391.imageshack.us/img391/3...0005rt7.th.jpghttp://img391.imageshack.us/img391/9...0006oy8.th.jpg
http://img46.imageshack.us/img46/736...0007qi5.th.jpghttp://img339.imageshack.us/img339/7...0008dl7.th.jpg
comments are welcom, just be advised, wiring isnt my best subject in comp building, but i try to do it so it isnt tooooo messy but hey, 4ghz perfectly stable oh yea, that reminds me might as well post it sooner or later
http://img129.imageshack.us/img129/3...ablepv6.th.jpg
how the temps? (cpu voltage is actually 1.45 in bios)
also, since i dont like working with metal too much unless i have the equip (i nolonger do) i was thining about making a fan mount/shroud on the rad out of wood... think it would work well?
Sticker? PSH.Quote:
Originally Posted by L'enFer
Its airbrushed.
Yes its an LL case, chopped up haha.
Not Very Xtreme, but my first try at water cooling.
It's a naut 500 kit on a 170
Before:
http://tspaulding.home.insightbb.com/before.jpg
One hour later:
http://tspaulding.home.insightbb.com/after1.jpg
http://tspaulding.home.insightbb.com/after2.jpg
-Pitt
Pit,
Nice and tidy, got to start somewhere mate and u have done a good job.:)
got bored, and decided i needed a fan shroud, so, i went outside, found some card board, duct tape was in my room, there fore
results:went from 44C idle to 36/37C and 54 C load to 45/46C
http://img56.imageshack.us/img56/35/pict0010my0.th.jpg
http://img153.imageshack.us/img153/6...0011an9.th.jpg
http://img153.imageshack.us/img153/3...0012qt3.th.jpg
Originally Posted by trance565
bootleg but its worth it for the extra drop :)
Sorry. Outta topic...
wanna ask u guys..
is ZEREX UV reactive?? or can it add any addictive to make it UV reactive in Pinkish color?
My system below.
yep, and imabout to ditch the cardboard and ducttape, ima get some thing ply wood (1/8th inch) and jb weld em together, so as to be able to transport it with out havin it fall off :D of course i will use the cardboard cut out to put over the fans, as its nearly perfect because of my 1337 box cutter exacto knife skillzQuote:
Originally Posted by whoodiestyle
use 1/4 thick, 1/8 is like flimsy...
That ghetto fab..... er.... ingeniusly improvised solution is awesome. :D:D
lol, septim : 1/4 inch is less flimsy, but if you use the right stuff, the 1/8th inch aint flimsy
lol ehtto fab is exactly what it is, took me a whole 5 mins
im not sure about the UV thing, but i put some dye in afterwards to give it a more greenish look, now its kina like a good green color, i used almsot an entire bottle of taht thermal take stuffQuote:
Originally Posted by daze
im also using too much zerex as most ppl recomend, lol im using nearly a 70/30 mix of DIwater and zerex instead of 10% or less
but it IS uv reactive now for sure lol
