Updated my contest thread. Check it out here http://www.xtremesystems.org/forums/...d.php?t=220984. Managed to get 0.02MHz higher BCLK for a grand total of 220.82MHz :rofl:
Don't be shy to reply ;)
Greetings all, it has been a while since I have been here.
I just fired up a new build using a Rampage II Extreme. I will be reading all through this thred over the next day.
In addition to the R-II I have an i7 920, 6 Gb Corsair Dominator GT, a GTX 285 and a pair of V-Raptors in RAID-0 powered by a Corsair HX100W.
It booted fine on the first popwer up and I have now flashed to BIOS 1104.
My initial CPU operating temp is 43 C.
Much to learn but it looks like this is the place.
ah finally somebody to compare
can u run in xmp profile for the i7 920 for the gt's??
just see whether it can pass memtest86+
Man, I want those sticks :p I can't get them anywhere though, nobody stocks them here. Not planning to order from US as it costs way to much. I would pay $100 in duty alone if not more.
I'm guessing though you had trouble with them because your board would not do high Uncore properly. I doubt I'd have trouble with them since I can do Uncore up to 4.4GHz comfortably so far in triple channel though I've said that before about this board :p:
hi does the Coolermaster Real Power 1000w Modular Power Supply work with this mobo thx for your time ;)
Hi :)
I've a problem, tonight i tried Galaxy 1000 - R2E - Corsair 1600C8 - 4870 512.
On boot VGA fan @ 100% and 3 red led on.
I tried with 2 4870, 8600gt and single ram on 2-4-6 slot.
The LCD poster just says welcome and then begins counting.
Incompatibility with the Galaxy?
Any idea?
Thx :)
Hi, which the best Bios for Rampage II Extreme x58 ????
YES I had the same problem! DROVE ME NUTZ! no matter what i tried couldent get it to fire up... went to Best buy and bought (and later returned) an antec 550w and it fired up immediatly. Just ordered the Corsair HX 1000 Which seems to be popular and works with the R2E.
which is the limit of overclock of i7 920 batch 3835Axxx?
What are slots 2-4-6? Are you using your memory in A1, B1, and C1 (blue slots)?
Alternatively, it could be your power supply. Did you plug in the 8-pin 12V power cable into the motherboard header and are you using the correct cable since some people have unknowingly forced their 8-pin PCIE connector into the motherboard?
If you have done all of this then maybe borrow one from a friend and try it would before buying a new one. The board seems to be finicky with the PSUs it likes. It's definitely an annoyance.
I had that batch number for the i7 940. The chip ran fairly cool but it did not overclock well relative to other i7s. I managed to get 4.2GHz but voltages needed to be around 1.45V. One thing I can say for sure is that the IMC on my chip was sub-par.
which the limit of voltage for CPU Voltage/QPI Voltage and CPU PLL 24/7 ???
I do not know what he happens here, that I obtain to stabilize with 21 x 192 1.40v, but in 20 x 200 I do not obtain to stabilize. What it can be this?
Will it do 18 or 19 x 200? Figure out your max bclk with low multi first and then up the multi.
Well, I did not post a screenshot but I did do that test. I did not arbitrarily declare it stable :D I tested Uncore up to 4211MHz using Memtest86+ 2.11 and Memtest HCI for a few hours. It went fine. Maybe if I redo the test on higher Uncore (4.3GHz+) I will post the screens then. I was definitely stable.
In terms of the memory, I do remember now what you told me in a PM. My bad. I remember that the board would run them but not in CL7. That still baffles me. But we all know that this board is far from perfect :p:
