Word!
So your telling me that my Rampage Extreme is a POS? If yes, I kinda believe that.
Hmmm, is that sarcasm or what? You have decent clocks for x48, but it's no secret that UD3P is king of the hill when it comes to 45nm quads.
Incidentally, I'm parting ways with my Q9650, UD3P, and 8GBs of G.Skills F2-7200CL4D. I've successfully primed them at 8 x 525, and 8.5 x 520. PM me if interested.
Edit: 8.5 x 520 with 8Gbs is my 24/7; just to give those interested an idea about stability.
@ zucker.. well well welcome to the ep45+q9650 godness :toast:
ep45-dq6
ep45-extreme
ep45-ud3p
+ thermalright ifx14 = 4.5ghz guaranteed
catch? no less than a 1000watt psu @ 12.5v
850watt @ 12.4 is not good enough.. at least not for a gtx285 @ 810/1620/1512 air/stock cooled @ heavy loads and q9650 @ 4.5
soon ill have about 10x ep45s and none ofem have let me down @ 4.5ghz.. except ep45t-extreme.. no ddr3/psu/q9650/settings/air cooler satisfies that beeotch
Are you sure its your PSU? Because Im having some problems to get my Q9650 stable at 4ghz+. Running only on a Zalman 600Watt with 4*16 = 64A on the 12V rails.
12V line = 12.56V idle and 12.49V load.
Because I get instant crash in 3dmark2006, while its prime + linpack stable.
well if you/anyone else want more info just search napalmv5 in this thread..
im sorry/i apologize but please dont ask/pm me about psu anything thanks
i made a covenant against talking about psu anymore.. looks like i broke it ahhh!! got to renew it
NapalmV5, thanks to you i could make 5GHz with Q9650:toast:
your welcome/thanks/welcome to the 5ghz q9650 club :toast:
glad more of you took advantage of my blabbing :)
This 5 GHz q9650 club.. the efforts in taming the heat this thing spits out at load.. very nice.
I have an interesting time air-cooling this chip's 4 Ghz prime95 runs. :)
I suppose real overclocking begins with real cooling, hunh? :)
XmX
As i said before I run my Q9650 at 4428mhz now (492x9) @ 1.4v on a 620w PSU which is only doing 12.03v on the 12v rail
On a rampage extreme too ;)
Just bumped it one nudge to 1.4v from spec in sig
EDIT: From what everyone is saying in this thread it sounds like I am EXTREMELY lucky to have this clock, on this mobo, with this PSU :p:
After a lot of effort I got my system stable @ 4000 (445*9)
PLL = 1.50
VTT = 1.34
VCore = 1.40 (LLC disabled, load = 1.28V).
Mem @ 1068 5-5-5-18 2.1V
Rest on AUTO.
- System is prime blend 8h stable
- Linpack 50 runs stable
- Memtest 8 hour stable
However, 3Dmark06 gives an instant crash and also 3Dmark01 crashes after 2 runs.
How to overcome these errors, more MCH? MCH at auto = 1.20
Anyone have any templates I can use for getting past 3.0Ghz on my EVGA 750i FTW?
I can post at 3.6Ghz, but I keep BSOD'ing or getting core errors on OCCT.
I set my BIOS to 1600FSB and Vcore to 1.28, trying 1.3v now. Everything else on the BIOS Voltages are set to AUTO and I have my RAM synced to my FSB.
System specs:
Motherboard: EVGA 750i FTW
CPU Cooler: ZEROtherm Nirvana NV120
RAM: 4GB OCZ ReaperX
Video Cards: Nvidia GTX 260's in SLI
Monitor: Acer P243W 24"
Power Supply: Ultra X3 1000w
^ get an ep45 if you want to really oc your q9650
and watercooled.. thats lucky ?
if you guys want lucky.. heres lucky: http://www.xtremesystems.org/forums/...d.php?t=206237 4.8ghz - all air cooled
if id want to watercool.. 4.8ghz fully stable easy peasy :yepp:
I like SLI, it does generate too much heat, but resale value of my GTX 260's are too low now.
I would get that board in a heartbeat if I didn't run SLI' but I went the gaming power route I guess.
I've upped my Vcore all the way up to 1.3125 which will be the furthest I will go, and it still fails OCCT. This makes no sense at all! I'm peaking the 70C mark too.
I just want to hit the magical 3.6Ghz.
I was able to go from 2.4Ghz to 3.0Ghz on my old Q6600 w/ upping the Vcore a notch and ran rock stable. I do the same here I Blue Screen... wtf.
Nice nice nice !!!
Not sure what to tell you with that 750i there. and why is 1.31 your limit. that is stupid. When Intel says the limit for vcore is 1.36 and that is just them being EXTRA Cautious. when really we can run these Q9650's at 1.4v all day!
Also nas, I think part of your problem is that ghetto Nirvana cooler, you have one of the best s775 CPU's on the market. that was a pretty penny to buy, yet you have a $25.99 cooler on it. I'd suggest you get a TRUE, or a S-1283, or a Cooler Master V8 on that thing. and then you'll be better. OCCT fails with anything over 62c. (That was OCCT's Default when I installed it on my system). so that could be why.
my 750i was only able to take my Q6700 to 3.66 Ghz. but my 750i got my Q9650 to 3.8 Ghz my FIRST time. and 4.0 Ghz was just a few voltage clicks higher. I've done 3DMark06 runs at 4.3 Ghz also. but not stable. but then I've never went over 1.38 on vcore either.. but that is because I live in a desert and didn't have water. but now I'm running water, and I change my voltage all the time. :)
Also, I was wondering if everyone here on this thread would post there current 24/7 vcore for there Q9650's. Also post your Max vcore if you'd like. but what I'm looking for is a list of 24/7 vcore's that people have run, and possibly for how long. I think these Q9650's have a vcore limit close to 1.5v just like the Q6600's and just like Nehalem, since i7 recommended vcore limit is 1.5v and they are made using the same 45nm High-K chips as Yorkfield and other 45nm chips.
So ya, can you guys post your 24/7 vcore on your Q9650's please. I'll go first.
I've been running 1.33 in BIOS, 1.312v CPU-Z at 4.0 Ghz for about 7 months now.
Sorry for Double post!
^ 24/7: believe it or not 4.6ghz on air/thermalright ifx14/ep45-extreme :yepp:
and no such thing as 1.5vcore limit :)
heres how fast q9650 is @ 4.6
http://img11.imageshack.us/img11/9786/safarij.png
http://img11.imageshack.us/img11/7976/chrome.png
