Just order 2 set of these. It is very similar to your ram cooler. I hope it work just as good as the Hr-07.
http://img27.imageshack.us/img27/3968/dragoonn422.jpg
Yeah that should work. Just remember you need thick thermal pads to make up for the height difference between the AMB socket/chip and the ram ICs.
STEvil,
I hope you don't mind me stealing your Asus logo.:)
hey Asus-guy!
Any word on a non-beta/final version of the latest BIOS 0105?
I think he withdrew into the shadows in sight of all the Asus-bashing going on here :rofl: :rolleyes:
I didn't see him (the asus rep) offer anything to anyone, including but not limited to promises of an upgraded Z7S without the failure rate. A fixed MB would have been ok with me. Maybe one without the overheating NB? I think the big corporation sent him in here for some damage control to quell the loudest of this group.
Hey guys I put it on its own photobucket account so mine wont get overloaded rofl :D
http://i853.photobucket.com/albums/a...sus/noasus.gif
feel free to pass it around, anyone can use it :D
guys, use the other linked image lol :D
Just got my rig oc to 3ghz. The memory cooler did the trick. Memory temperature now in the 40C.
Hey GUys,
Now that I am able to push to 3GHZ, my PC would randomly shutdown. SOund like a under supply power issue. SO I went out a bought a Enermax REVOLUTION 85+ 950Ws online. That bad boyz is sure expensive. Supposedly it have 87+ AC to DC rating. One of the best PS in the world I guess. Going for 450 FSB next project after the PS comes in.
I also notice an improve response on my system after running my system at 1600FSB with snoop filter enable. Try it with w/o SF too at the same FSB. Seem to be better with SF enable. I guess the improve bandwidth enable the SF to work correctly this time. Maybe my brain is playing trick but the games sure does play better overall. :yepp:
Any one here wants and unwanted 750watts PS with full cables and box. :D
the option is called 'Snoopfilter Bypass' , so by enabling this option the snoopfilter is disabled . At least that's my understanding .
Yes, that's right. Performance is approx. 50% worse with SF bypass option disabled. See post 1, first line :p:
As promised: http://sites.google.com/site/ultimatehtpc/
Again, thanks to everyone for steering me away from the Z7S for a new machine... This new build rocks!
@jcool
http://img.photobucket.com/albums/v4.../Capture-1.jpg
Did you try to mod the bios of this board? I used AMIBCP and found some disabled/hidden options (CPU ratio CMOS setting, etc).
download AMIBCP from this thread (look for Bios Tools Pack)
http://forums.mydigitallife.info/showthread.php?t=529
Erm.. there already is a CPU ratio setting in Bios. No need to unlock that.. what I would like to unlock, on the other hand, is CPU VTT voltage.. but that can't be done, apparently. Would need a hard mod.
Yeah we already covered that poki.
the board is a POS though so no point in digging for new bios options really.
Hey guys, been watching this thread for a loooong time. I've been running a Z7S WS since May 2008 and when I first found this thread it made me nervous. Thankfully I have had zero issues with mine (knock on wood). I've run it from day one with a HiPer 880W PSU, modified (to fit the AMB) MassCool aluminum heatsinks on the RAM, and Arctic Cooling PWM fans all around. I don't know if that is what is making the difference in my case or if maybe I just got lucky, but there it is. I have left the machine running for literally months at a time. The reason for this is that I travel away from home quite a bit and I still like to have access to my Outlook and Quickbooks data. I also use Media Center + Orb to keep up with my shows on Adult Swim while I'm away.
Anyway my intent is not to brag. Actually the reason I am finally posting is to ask if anyone has abandoned their Z7S and maybe has some Kingston HyperX KHX6400F2LLK2/2G FB-DIMMs sitting around that they want to get rid of.
Thanks!
Wow, that was fast. I've purchased 4 HyperX FB-DIMMs from an Xtremesystems.org member, but I'd still like two more for a full set. Anyone else have a pair sitting around, collecting dust?
