u say it man !!!Quote:
Should it be said … or not. Of course, it should. First off, the difference between diplomacy and “social etiquette” is the difference between truth and untruth. Truth, which is another word for unity and untruth, which is another word for division, is also the difference between real power [or reality] and relative power [or imagination]. For those coughing blood and fuming about religion, crapola and similar at this stage, cough more [the whole lot, if possible] for it has to get worse before it gets better.
Nobody needs to be diplomatic about a “secret” bios as if such a nonsense exist. It’s about relative power [yeah man, feeel the powahar] which is selfish empowerment to the detriment of others’ feelings. The feeling that you’ve paid a lot for some pipe-dream and all because pimps and their whores have done a good job on you. If those with some brains still intact were to take a step back and reflect, none of the so-called overclocking boards make much of a difference when it comes to performance and there are no exceptions here. They perform much the same in real world applications, clock-for-clock. The idiots and lunatics with their great technical write-ups are part of the selling food-chain. The selling of dreams of Bushido [a real con relative power crapola and used to good effect by gangsters and the military all over].
Take a realistic view and that is you are only as good as the lottery-strike CPU followed by expensive memory and that’s just the silicon, not forgetting even more expensive cooling. It has little to do with a human being. Where the human comes in is when imaginations start flying. Nobody is going to con Intel out of a few hundred bucks worth of performance because they’ve already sold you something that costs little in the grand scheme/scale of things. That’s why they’ve locked the multiplier. Let the juvenilles and their self-perceived greatness justify their need to play with their danglies but don’t let them persuade you that they are not actually playing with their tiny dangly bits. They are. Don’t beg and fuel their aggression/disrespect for others. Enhance your self-respect instead and vote with your pocket…. next time for there will always be a next time for what goes around, really do comes around.
A secret is when you do not know about it but disrespect/aggression is when you’ve been lured by it. Ever heard of the whore that you can never buy? That’s called a time bomb. That’s the one that wants to own you, not just some of your money. Some might even sceptically call that a spouse.
I didnt know Xs had a pulpit. Whens the next service? :stick:
well, some would kill for first spot on 3dmark06 page, others not..
as for the new bios, still tons of issues to fix before 1333 strap which abit sayed on release that the board will get it, so no big secret here..
i just want an bios which dosnt require phase to make the board be highly ocable
Originally Posted by cir108
clock for clock comparisons are valid on xs when the cooling limits are similar, for those with superior cooling capacity the maximum speed a board can run at becomes important (if it pull away in performance at higher fsb's), if you look around you'll see threads comparing straps and performance, so people are not really too blinded here, not too mention the mentallity of how much is enough or too much..;)
regards
Raja
what 's going on here ?....http://i51.photobucket.com/albums/f3.../surrender.gif
I got a p5w dh dlx and that is totaly fubar.
How is this abit card ?
i've had p5w dh dlx before and it's just couse trouble to me, this Abit aw9d-max is much better and more stable, it boots up just fine and no waiting minutes to se a screen, i am more satisfied with this board than p5w dh dlx because it was the worst crap i ever had..
no more asus=anus in my house :(
Phase really has nothing to do with the oc'ability right now as the limiting factor is the mobo and not the CPU. It's the boards lack of adjustments and lack of high of FSB's which are attainable only through vmodding which are making awesome overclocks unattainable.Quote:
Originally Posted by Hilfiger
Board isnt doing too shabby on water :D
http://www.sspmustang.com/OT/x6800/4...n-32m-run1.JPG
Man, that is some serious voltage ur giving that poor cpu.. mine is Pi 32 stable @4113 (457*9) and 1.55V. Have you tried lower?
That voltage looks a bit much for water :/
Originally Posted by FragTek
He's only at 50c, whats the big deal? Have you even seen a dead conroe from voltage?
Anyways, if this board gets the 1333 strap that would be very good, hopefully DFI does it with the infinity too and we will have some king 975 boards. Maybe some new SLi drivers for it and then things would be great.
i get that fsb at 1.6v, but i cant go over 410 for some reason, and i have 50c on airQuote:
Originally Posted by Revv23
that's very strange. have you tried messing with the trfc value?Quote:
i've found that in order to boot above 405, i'd have to loosen it up quite a bit.
also, i think a default 9x chip seems to obtain higher fsb's than a default 10x chip.
i had a hard time booting at 420 with my 6700... now i can easily boot 425 with my 3060, vmch = 1.85, and vfsb = 1.49.
ehem, hes at 50C IDLE, not load. That indeed is pretty dang high...
...that may be, but aren't the AW9-D's temp sensors like ~20C on the high side?
CoreTemp shows core1 @ 63*c... AT IDLE. That's burnin up, kick down ur voltage man.Quote:
Originally Posted by Budwise
yea, they do read high but id still be dropping those volts down regardless...
No, I don't think they are THAT off.Quote:
Originally Posted by ErikaeanLogic
between core temp and uguru, temp differences are only 2-3C's.
My idle temps are usually around 35-37C's with room temp of 24-26C's.
It is only 1.68v load and about 1.7v idle, what is so bad about that :toast:Quote:
Core temp shows 77c priming 1.63v, I have had cpus that show 20+ less or so!
I will say it again!
THE ONBOARD SENSORS INCLUDING CORE TEMP ARE NOT ACCURATE!
Could someone who has done the vfsb mod answer a question for me please. I know the only way to get a true reading after the mod is with a digital mm but since I've completed the mod the board has been reporting 1.9v in uguru no matter what the vr is set at.
I'm just trying to make sure I'm not the only one getting a wrong reading because if I'm still supposed to be able to see a correct or close to correct reading there may be something wrong with my mod.
Has anyone actuly tried to load saved settings by pressing F7 ?
Swaped in a new VC, and like all ways my settings were lost, pressed F7 chose to load saved settings, escaped back to main menu and chose save settings and exit. Greeted to a blank screen, and thats as far as it goes :confused: waited a good 4 mins and nothing at all happened, reset does nothing, holding power button does nothing.
Powered off {by PSU} swaped back to old VC, power up and nothing power button dont work, reset dont work.
Cleared CMOS, still same thing, pressing power button does nata.
Yes. I have used F7 before and it worked! :) and loaded fine as well.Quote:
Originally Posted by Blue078
the vfsb is cpu vtt i believe in uguru.Quote:
Originally Posted by MrDeeds
i've measured it with a DMM and using uguru and they are only 0.02 volts different.
