Reduce LDT to 2.5 or 2 and max async latency to 9, 10 if it helps. read preamble might help a bit too, not sure.. try 6.5 or 7
i set most of the 0615 machines i built to 2800@1.35v. so they load temps were about 42-43c. those are air temps though. i only built 7 machines with 0615s. one of them wouldn't 2800@1.35 due to temps. was getting up to 53c. so i sold the chip itself to a friend and i believe he's going to delid it.Quote:
Originally Posted by Repoman
as you know the CCB1E's are probably going to run a little hotter, but they also handle the heat a little better, and can take more variance in heat than the CCBBE's.
as repo said. drop the LDT multi... and did you mention what RAM divider is at?Quote:
Originally Posted by Rapier
Receiving a 0610 DPMW *904* on Sat, hopefully will be 'clocking by Sat night or Sunday. Wish me luck! :D
P.S. Got it from Monarch, OEM, ordered May 19th (I *THINK*), when the $70 off 165 deal was still going.
How do you know the stepping?Quote:
Originally Posted by manomanx2
nice, you are one of the last lucky ones that got that stepping from monarchQuote:
from this pic you should be able to figure it out :)Quote:
Originally Posted by csimon
I think he meant, how did I know the stepping if it's coming Sat. Well, my friend received it today and will be handing it off to me on Sat. Hehe, sorry for the confusion.
Ya, initially I feared the worst. Pretty cool that I got lucky!Quote:
Originally Posted by itznfb
No, I think he meant how did he know what stepping he was receiving from Monarch...Quote:
The LDT in my setup is a non issue, my mobo can fly at HTT speeds of 1500...it's something else...I'm gonna try to run F_tester, if I can figure out how to use it, and maybe reinstall for the f'in millionth time...sigh...
lol, excellent point ;)Quote:
at worts i believe you would have received a CCB1E 0609FPMW. still an excellent overclocker.Quote:
I hope you do man!Quote:
Originally Posted by Smalltimer
Cant recall cause it was cooler than it has been lately when I took that shot but normally at ambient 75C I get about 46C load. I am pretty sure that I was able to hit 2850mhz on stock vcore.Quote:
Originally Posted by thunderstruck!
yea i think i'm the only one that missed that... doh :slap:Quote:
Originally Posted by phi|os
are you trying to find max total or max cpu? if you're trying to find max cpu then you definatly need to drop that ldt multi if you haven't already. you need to take that out of the equation. drop it down, and then if its still no go, then you have a better starting point.Quote:
naw, i'm not doing the max, i'm just trying to satisfy myself and close the book on this damn CPU by getting it stable at 3Ghz. This mobo I have is god damned tricky. I've hit 2.9Ghz on 1.42V, and with some burnin maybe can drop it a little bit. Right after that I jumped up to 3.0Ghz, and it boots and runs fine at 1.45V, but won't :banana::banana::banana::banana:in prime. Now I'm at 1.55V and realize that I don't think it's the CPU.
I'm surprised I'm not typing in caps, cause I'm pissed. seriously.
i wouldn't be too frustrated if you can't get it 24/7 stable @ 3ghz. you're on air right?
Just ordered a 0606 VPMW from flickerdown
I must say, the chap running the place has been extremely helpful (and patient) despite my indecisiveness along the way.
I will post my results here as soon as I mount and test the chip.
If all goes well I will rinse and repeat the process in hopes of a pair of high clockers :) for a small 4 way rendering cluster on water.
I will post pictures also of my 8 slant rackmount.
nice. i bet dave is happy he's starting to push those out the door. i don't know why everyone is having trouble getting rid of those chips. they are excellent steppings.Quote:
Ya, well I for one am happy he has them.Quote:
It's better to have matching numbers to sell later on in my oppinion plus I will have a better chance of getting similar performances between the two chips if they are from the same tray. :)
I was hoping for 3G's but after some reading I guess 2.9 would be excellent also. I am at 2.4 now on my workstation so 4 rendering pipes @ 2.9 would be a blessing!
Also I think you refered me so I guess a thanks is in order as well:toast:
I took his advice and she is at ~3008 (9x334). Just ran 5+ mins of SP2004 and got an error on CPU 1 at test 3. Now she is talking. BTW itznfb, I had it DDR 300 during the test using 4x512mb Geil ram, effectively at 250.5 FSB. Memory numbers lower now as expected (5209 Int and 5140 Float in Sandra)Quote:
Still Tweaking. Any more advice?:clap:
Yea, but dual prime with 1.55V only pushes temps to 40C. The only thing that can get this processor running hot is the toast program(dual instances). That pushes it to 46C, 1.55V. I don't think the temps have anything to do with it.Quote:
Right my RAM is at the 150 divider, I'll drop it down(which would make my RAM below stock speed) and see if it plays nicer.
don't worry about them mem bandwidth yet. lower the divider some more and see if that gives you longer stability.Quote:
temps are accurate?Quote:
i clock much higher when ram is below stock speed. just remember these chips are incredibly sensitive to memory settings due to the odmc.
Ok. Now for some CS:S testingQuote:
:D gotta love game testingQuote:
oops smalltimer i was just went online to tell u where 2 get the 0615 but i guess u already got a 0606. Oh well more for me :D:D:D. Btw they're in Toronto dunno where u r in Canada so might not have helped anyway.
Btw itznfb i think ur doing a great job with the chart so i'm glad its back up.
