Originally Posted by
squick3n
Question about fan control and settings. In UEFI, what should I set the fans to if I want to use a Windows utility to control them? Auto, full on, or manual? I'm guessing either auto or full on. Also, how is the AsRock utility for fan control? It seems I can set a temp threshold and have it respond accordingly. Does that work for 3 pin fans as well, or just the PWM fans? Is the utility any good?
Manual says to use the top most PCIe spot for single card, and top two for 2 card setups. Is it okay to use the middle one for a single card setup, and first and third for a 2 card?
Bit-Tech review from near launch said the board had poor SATA 6.0 speeds. 10%-20% slower than the Asus Barefoot. Is that still the case?
Thanks for the help, and the wonderful thread!
