Added the tags for you. :)
SimpleTECH | Core i7 2600k [4C 8T] @ 5000MHz | 1.440 | Asus P8P67 Pro | Water | L040B208
http://img823.imageshack.us/img823/7...0001440v1a.jpg
http://img403.imageshack.us/img403/1...0001440v1b.jpg
3dsag3 | Core i7 2500k @ 5000MHz | 1.38 | Asrock P67 xtreme6 | Air| L042B144
Hopefully I can submit, multi is @ 50, but for some reason bus speed drops below 100 even though its set at 100 in bios 0_o
http://i2.photobucket.com/albums/y9/esi-slowboy/50.jpg
to new height
1.5Vcore
http://img641.imageshack.us/img641/232/51ghz.jpg
wibujo|Core i7 980X[6C 6T]@4727MHz|1.552|Gigabyte UD9|water|3020A431
I plan on getting a 990X and thought I'd post the best I've been able to OC this 980X. Was working on 4.84GHz - just couldn't get it stable. Soon as I find a new home for this chip I'll upgrade. Anyway, here's my results:
[IMG]http://img337.imageshack.us/img337/3966/4727.th.png[/IMG]
[IMG]http://img26.imageshack.us/img26/6506/47271.th.png[/IMG]
I just had to go for 4.5 and got it. I just need to get the temps down some.
http://bellsouthpwp.net/o/w/owen2863/small.jpg
well my new i7-970 seems to be a great one for sure:D
i was having trouble getting it stable,random failures at all vcore
ranges,then i remembered to use the x17 uncore(my E760 hates x16)
when running x8 memory.and if i keep it below 60c i can get through
20 runs w/1.36v,but once it goes above 60c it needs 1.37v it seems.
http://valid.canardpc.com/show_oc.php?id=1669892
21x215@4503 HT ON w/1.36v
http://i56.tinypic.com/27zhfev.jpg
http://i54.tinypic.com/2lwvjab.jpg
It is not because Linpack is poorly optimized for Sandy Bridge chips. Linpack is a standard SIMD program, which is born to be against HT. Forcing 8 threads on a 4C8T CPU would only get worse Linpack performance due to overheads caused by context switch etc.
Thanks.
I just re-installed that chip and tested a little higher at the same Vcore. (HT off in Bios). Think I need to remount or I used too much AS5. Had to be real close to throttling
crossg | Core i7 2600K [4C 4T] @ 5022.8MHz | 1.416 | ASUS P8P67 Deluxe | Air | L038A660
Got 4.5GHz with 1 stick of ram, and will post back when I whack another one or two in :
http://i194.photobucket.com/albums/z...inx25hrp95.jpg
I don't mean to crap on your parade, but if you read the first post Zalbard states that you must a show a screen shot of linx running after 20 successful passes, i.e. set it to run 25 and take screen shot after pass 21.
Other than that everything looks good:up:
That's a good one :up: . That's a good vCore for 24/7 on a 6-core.
With the resent 34% price-drop, these 970 are good and "affordable" alternatives to SB now.
I'm not sure about the production date on this chip, but those produced after Intel's move to 990x can have a really good OC-headroom.
So new 2500k Batch L047B217 5.4Ghz :up:
http://www.abload.de/thumb/linx5.4ghzace5tjm.jpg
Ace. | Core i5 2500K [4C 4T] @ 5400.0MHz | 1.560 | ASUS P8P67 WS | Water | L047B217
Heres another one for your great club Zalbard, this is my 24/7 setup
Gigabyte GA-P67A-UD5
i5 2500K L050A864
4GB GSkill Ripjaws X F3-17000CL8D-4GBXMD
1 X HD6950
OCZ Turbo Cool 1200W PSU
120GB OCZ Vertex SSD
Thermochill PA120.3 Rad
Laing D5 Pump
Swiftech Apogee XT Waterblock
Windows 7 Ultimate (64 Bit) SP1/AVX :up:
http://i106.photobucket.com/albums/m...645GHzClub.png
Thanks! :)
Also, nice job with overclocking and formatting your post! :up:
Yes, it does! Very nice! :D
You have a really good chip, actually. Great clocks! :up:
Speechless... You should try your luck with AVX! :up:
Thanks, and a nice rig you got there! :)
@ 3dsag3, dragonhunter, In-Fluence:
LinX has to be still running / calculating when you're taking your screenshot!
That's Hot Girls :mad:
Ace. | Core i7 2500K [4C 4T] @ 5300.0MHz | 1.568 | ASUS P8P67 WS | Water | L047B217
Thx :D
5400 is not Working in the Moment but I work on it :confused:
you deleted my 5400 Run?
Replaced it with your AVX run. Not much point, really, since, for example, 5000 w/AVX >>> 5200 without...
AVX is where the real 5GHz club starts, under 100 GFlops is just for starters. :p:
I hope more people will re-submit w/AVX so I can shrink the "Under 100 GFlops" category and leave it for non-SB chips only.
