Yah would probably be a wise idea to find vgpu measure point before I go ahead and do it.
Post a pic of the back of your card and I might be able to find the measure point.
Nice going on that 4870! Congrats for setting a new record in Vantage! :up:
I'm waiting for improved 03 and 05 scores! :D
The 8800 series are nice cards... Do you still have your Core 2 setup so you can go for some points in 01 as well?
Don_Dan: nope, sold my E86 to jor3lbr/elano and my ud3p to another guy a few months back or I'd be kicking some 6ghz 01...
Looks like I can get 10 points or more for 01 anyway with my i7 at 5.1. :D
Too bad, 10 points is good though.
I will go for 01 with my 8800 GT when I have my REX + E8600 going, I just need to figure out why it won't pass 01 at more than 700MHz while 05 would not even crash at 750MHz. :(
Can someone please find ~40 points? :D
thanks dan i would get those missing points, but i'm having some issue here
i've run 03 and 05 and i get significant lower score with 50-75mhz more on gpu i don't understand, plus i keep getting "irq not equal or less" BSOD and can't figure it out, sometimes pc wouln't even boot with setting I've run so many times.
i should be good for 06 silver at least when i get this rig working properly
so i'll have to delay aq3,03,05 when i can clock this cpu properly
i'm kinda bum right now, it was going so smooth friday and early yesterday
need a break, and i'll get back to work tonight if possible
Mk-ultra, if you'd like some good hardware points o should have some 8800s for sale when I'm done with them... ;)
good luck with your clocks with those 3dmarks... Hope you can stop the bsods. :up:
I've had a bit of bsod trouble with stable clocks too...
Nice work with the 4870, I actually ripped mine out of my 24/7 rig which is why I didn't beat on it to hard, glad you are picking up my slack. I will follow through on 4890 and 4850 class seeing as both cards are disposable :)
i might be interested, but i still have work to do with those i have here. I got a gpu pot coming for getting some more cups!
btw, bsod was (i hope so) too high uncore
thanks chew, but can you help me here? or anyone else for that mater?
http://i.imgur.com/5HxT4.jpg
i can't figure this out, look @ gt2 and gt3....wth is wrong, i could understand if all tests were slower but only 2 with much higher clock on the gpu is weird.
i tried lowering gpu clock to 860 but still same effect
Well, i had a crappy day of benchmarking. Didn't have the right OS's and 3dmark 06 WOULD NOT work because i was using a 64bit OS. gah.
Anyways, so i just got ONE today (facepalm) Grabbing 3dmark 03 tonight, and benching that in the morning before school.
http://hwbot.org/signature.img?iid=3...se&iehack=.jpg
Also had a little trouble... Wasn't too bad though. :)
Couldn't get 01 to run... would stop in one of the middle tests... Should I reinstall it?
Its on a fresh XP 32bit install with all of the other 3dmarks working fine... Tried it with the GPU@stock too just to make sure it was't the issue...
Can't wait for the other 8800s to come in! :up:
i couldnt helpt myself either, bidding on some 8800gts / 8800gtx / 8800GT models :D , they are just to much fun :P didnt hear nothing from my 5870 yet, hope to hear something soon.
You beat my 05 score by a small margin, damn... Keep on pushing, your card is a lot better on shader frequency! :up:
Yeah, reinstall should fix it.
Guys, check this out: Explicit content inside.
I wish more categories looked like the Q9650 Wprime category:
http://img690.imageshack.us/img690/8...mecategory.jpg
30 points left! :up:
I'll wait for the gigabyte SOC card ;)
Guys... I just checked HWBot for news. Hipro5 is back. Benching hd5870 in vantage at 1420/1420....
I shall now stop benching and bask in the glory of raw megahurtz.
Yeah, its a good oc'er. I think i can push it a little more and break into 27k, but i just don't have the time, have some finals this Wednesday. CPU is stock at 202 bclk. Can't get it to go any further, so i am glad i am getting rid of it. Hopefully the next 920 is better.
7600GT XXX edition incoming... :D
Thinking about selling my 5870 for a Kingpin GPU pot to max out these cards on something cold...
Still looking for an 8800GTX...
