i Had run som stability tests
hey again maby its time to just say Halo and post my settings after some stability testing :p:
my rig
P5Q-Pro. + 1613m OC bios
Cpu Q9450@4GHZ
2x2Gb OCZ DDR2 PC2-8000 Platinum
3x250mb Vestern Digital 2 in raid 0
Writemarster 35 dvd+/- rw x16
Tremaltake Trughpower 1200w 98A
Club 3D 3870x2 825-900 Bios Flash To 851-941 + overdrive At 945/1100
cooling
6x120mm sinkel ROHC with 12x120mm Fans mounted in serial
Laing DDC - 1Plus 18w - Reservior XS-PC - cpu Head sink Thermalright Water Block XWB-01 - Nb EnzoTech SNBW-SLI - Sb original Headsink + 40 mm fan - GFX EK-FC3870x2CF-ACETAL
At 500x8 1:1 ram
i can run at 1.368 V but to get stabel in Prime 95 p64v258 for 4 Core's i have to run at
cpu 1.425 - Nb.1.58v - Sb.1.3V - Pci/sata 1.6V All setings are in bios :shocked:
That stres test runs the cpu at 100% i onley run for 15 min and max temp on Cpu was 38' the hottest cores at 62' after 15min max load
do enny one Know The max stable temp on The cores at Q9450 ?
maby i cood try to Hit 525 Fsb :D
