Originally Posted by
Zucker2k
In as much as I respect your opinion, you're wrong. You're making a very basic mistake here, and as an engineer I believe you will understand this. A northbridge with a thermal envelope of 90C is NOT rated to run at that temperature at ALL FREQUENCIES. This last word is key, and that is why I said earlier that once you start overclocking, all those numbers are out the window.
This is why cooling is so important in computing. So yes, while the NB would run at 90C at stock without the stress of overclocked components eg. ram and fsb, it will not do so once you factor in these other variables.
This is why I think what you say is so misleading. Intel is not misleading us by saying that the NB will operate normally at 90C because Intel does not, and will not base their figures on overcloked chips. That is why there is always a disclaimer about running components within spec. So if you want to convince me that one can run at 90C at all frequencies, then show me some other numbers, eg. voltages, frequencies, fsbs, etc. To be so adamant about this argument is very interesting because this is XS, and members here do push their equipments to the limit. Heck didn't Intel seek out our very own Fugger to do its demos? If you want to continue this argument, I recommend you qualify some of your statements or show us some screenies of a 'pushed-system' priming large ffts with the nb temps close to 90C :D
