I wonder when you gonna start the new project.
Are you working on it right now?
Here you have temps after 8h
http://www.abload.de/thumb/beztytuukrdz.png
I have two rads ;) Not one. On top is f1 xchanger 360, on front f1 xchanger 240.
On stress temps are little higher.
I think maybe in q4 of this year... now i don't have time for this. A lot of work in clinic.
Hi Malik
Can you tell me what size compression fittings e.g 1/2"ID (5/8" OD) , 3/8"ID (1/2" OD) ,3/8" (5/8") or 7/16" ID (5/8" OD) and the size of tubing 7/16" ID (5/8" OD , 3/8" ID (5/8" OD) ,3/8" ID (1/2" OD or 1/4" ID (3/8" OD) for the barus qpi block in your bloody red project. What would would be the biggest com fittings and tubing would fit?
:D We have the same mousepad!
Right thanks for the info.I've seen Screamer's build very similar to yours a great looking rig.Also from Poland is he friend or relation?
Soon, when i finish cables, i will make a movie ;)
For now .. trailer: http://www.youtube.com/watch?v=1_wQz3I76l8
i rofl at the sound of the trailer :D
hahah i know it ;) Asian Dub Foundation rulez ;)
Malik, what is that background music, sounds nice? The trailer is better than a lot of movie trailers... Viewer knows that will be something great when Malik is directing it. :clap:
Here you have this song: LINK
Hi Malik, what blue fans are those ? They look really neat.
You have all info in this topic. I mentioned this about 10 times, what kind of fans i have. :shakes:
Little change in ram block - nb connection. Earlier bend was "crashed" :(
So now it's looks like that:
http://www.abload.de/img/dsc_1435h7w5.jpg
http://www.abload.de/img/dsc_14225me6.jpg
http://www.abload.de/img/dsc_1433yv9v.jpg
Hello Malik, what for srews do you use to mount the ek supreme at the Mainboard? Because the screws which are included in the the supreme are silver and such big mountin kits..
This are m4 screws.
normal M4 screws with a length of 16mm? or how long are your ones?
LINK
Good idea :up:
Yeap, this are 16mm screws.
thats cool. SO you use 8 M4 16 length... cool, so i save the 10 euros for a Black mounting kit ... blackplate i have one to fit^^it is black too
Malik, this will be your next upgrade? :D
http://i.imgur.com/LttLn.jpg
http://i282.photobucket.com/albums/k...reme/R3E01.png
:up:
I don't see how such red mobo will fit with blue theme .. and imho yet another red&black build is not worth Malik's skills to be wasted on :)
I wonder if someone will explore some less used colors . eg. after seeing orange crush mod (TJ07) i was very impressed. Pitty though that it's hard to find matching pc components that would fit in such themes.
Two years ago ... i was made orange project too ;)
http://lh5.ggpht.com/_ewMJ_gKYs2k/SM...0/DSCF0776.jpg
Do a blue and gold build!
Haha, when I scroll past that motherboard ^^ the PCI Ex slots look like they're not moving.
