You can install the utility softwares under vista using compatibility mode. right-click the .exe, properties, compatibility, etc. etc. hope this helps.Quote:
Hey! That's great news...thanks for posting it! I really just want Vista on my new PC. :)Quote:
Originally Posted by Zucker2k
The fact your machine is rebooting quicker everytime you increase Vcore may indicate a temp issue. Those Quads can generate alot of heat. May help to diagnose the problem if you provide the CPU load temps.Quote:
Originally Posted by Elfear
For a simple test, try lowering your room temp (open some windows, etc.) and see if ORTHOS can run longer with the same voltage settings.
chipset cooling ?Quote:
I've had similar issue and a fan over the stock chipset cooler helped
I have pretty good airflow over the chipset with two 120x38mm Sanyo Denki's sitting right in front of the board. I also thought that if I tried say 11x327 instead of 10x360 that it would place less strain on the chipset and rule that out as the culprit. Am I correct in that thinking?Quote:
Originally Posted by Supertim0r
Temps are 55C with all four cores loaded at 3.4GHz@1.34V. Temps don't seem to vary with increasing vcore. It's kind of weird.Quote:
Originally Posted by syl
I'm no expert whatsoever, but I was suffering from the same problem as you. I solved it by setting my processor and memory to automatic first (so no overclocking at all). then I underclocked my memory to the desired setting. Mem Ref 266 and mem freq 533 plus desired voltage etc (I have 800 mhz memory) Restart the system and then change the fsb.Quote:
Originally Posted by malficar
In that order the mem settings were saved and I was able to overclcok my system
Did one fresh install and one upgrade from XP Pro...
The Intel RAID, Intel Chipset, Intel Lan and Sigmatel Audio drivers from Vista all work with the following notes... The Intel Matrix Storage manager won't work because the Vista driver is newer than the Intel supplied one (no big deal). The Audio driver will have problems on upgrade if you don't completely wipe out the Intel supplied driver before the upgrade. Before you uninstall it, get the driver details, then make sure there are no traces left of those files after the unistall.
The Marvell isn't supported yet natively but the drivers supplied by Intel (including the Marvell console) work fine.
IDCC won't install even in compatability mode.
IDU is OK.
TAT is OK.
I read the first 10 pages and the last 7 pages.
So this board does not allow for multiplier adjustment.
Are there any programs that can be used to change fsb in windows?
Clockgen possibly? if so, which pll?
It's all fine now with 2507:Quote:
Originally Posted by Steven_nl
http://img236.imageshack.us/img236/1...2507zi8.th.jpg
I turned the following off; Watchdog, C1E, EIST and VT. Watchdog and C1E may be accesssed by moving the jumper and entering the BIOS then.
Great!
I could overclock a bit more (3.6mhz) but my temps were getting higher then 63C in Orthos with full load. Am unsure if that's to high so I'm sticking to 3,2 Mhz
Not yet on Clockgen. The Intel Desktop Control Center will though.Quote:
Originally Posted by shimmishim
Thanks! I'll give that a try.Quote:
Originally Posted by gtj
Wish there was a way to access lower mults...
9 x 400 would be sweet vs. 10 x 360 :(
guys i just put this board in my system .. swapped out the 680i cuz it was dead ..
badaxe 2 rev 505 .. latest bios .. running a e6400 .. cou has done up to 3.6 on the 680i
no matter what i cannot get past bios at any overclocking ..
it always brings me to a screen that says
something about the POST having problems
press Y to enter bios or press N to try and boot with previous settings ??
no matter what i cant get past that screen
someone needs to write a guide :)Quote:
Originally Posted by jetjaguar
put the jumper in "maintenance mode"
then turn off C1E and Watchdog
then overclock to hearts content! :)
I have been digging around some of the documentation that I downloaded and all I can find is this:Quote:
Originally Posted by Severance
In addition to the standby power indicator, the board contains two LEDs that indicate
the following:
My guess is that the pelt is making the sensor go out of range at startup, some fine tuning must be needed.Quote:
• The CPU LED indicates an elevated temperature on the processor that could effect
performance
• The VR LED indicates an elevated temperature in the processor voltage regulator
circuit that could effect performance
Figure 16 shows the locations of the LEDs.
did that .. still no go .. dunno why
weird. i was stuck at 3.0 ghz.
after i turned off watchdog, i'm now at 3.7
can someone help me out real quick? i've been looking for that Intel sheet that has the BIOS post codes on it ("BA" "00" etc) and I can't find it. If anyone knows where it is, could you please post the link?
ftp://download.intel.com/design/moth...D7364501US.pdfQuote:
Originally Posted by moosey
you ARE the BX2 man! :)Quote:
I've only had this board for 2 days now and I'm lovin' it!
This board should hold me over nicely until I'm forced to change chipsets again... <sigh> *I HATE INTEL ONLY WHEN THEY FORCE ME TO CHANGE CHIPSETS*
Originally Posted by Ajfina
There any better places to buy from other than this deal? Tempted to pull the trigger
At the moment, this is the best price. The next cheapest is tigerdirect for $199.Quote:
Originally Posted by JamesAvery22
Wow...
I've been able to run 4ghz fine before on air, but on 1333 strap.
Last night I vmch mod
Boot up to install xp on a 40gb IDE drive to bench
normal xp pro and nlite'd xp pro black screen
xp x64 works fine
4ghz doesn't post at all
get it to run stock, flash 2507 from 2333
Watch dog at every clock
disable watch dog, stock doesn't post
post stock with 1 stick of memory and get 3.6 working again
The ability to have this board POST is just awful. It NEEDS clockgen. I love the board, it's fast, it's stable, but pushing an OC on it is a nightmare and I'm on the verge of selling it for a commando :(
keep this board mate ;)Quote:
Originally Posted by afireinside
Why should I? Every time I try to OC it I get to pissed off to think straight.
Now my old 3dmark stable clock of 3946mhz freezes idling windows. Did my CPU degrade? Wtf? My old 6600 did the same thing, 3700 ran fine 24/7 for 2 weeks then only 3600 worked.
