Originally Posted by Delta
Hi all, im new and been reading here for a long time. I built my new system and everything seemed to work fine. Boots up and posts all information. My problem is getting my RAID 0 to work on the Intel matrix ich7r! Ive grabbed the RAID drivers off the Asus cd and put them on a floppy. Ive made the Matrix array and set up my Bios for it. Also disabled the 1394 firewire and jmicron in Bios. ive hooked my HD's to Sata1 (red) and Sata3 (black) connectors using the RED sata cables. When everything boots up , I hit F6, and install the RAID driver (intel 82801GR/GH SATA Raid Controller Desktop ICH7R/DH ). IT all loads up fine and then proceeds to start loading windows. Gets as far as saying "Starting Windows", hangs for 2 seconds and then gives me the BSOD !. Ive tried Moving the SATA connectors to Sata 4 and other configurations. Still BSOD everytime.
When i use the Orange sata cables onto the Ez-raid ports, Config the Bios for ez-raid 0 and the jumpers, it will load windows and all is good.
I want the better performance out of the Martix Raid 0 instead of the ez-raid0 .
My system specs are:
E6700 L629a434
P5W DH Deluxe Bios 1305
Gskill 6400 2GBHZ
7900 GTO
3 SeaGate 320gb 7200.10 - want raid 0 on 2 and 3rd for storage
Zippy GSM-6600p (G1)
Any help would be appreciated. Right now im going to Reinstall my OS (xp home sp2) on the ez-raid sata ports just to get this up and running for now untill i can figure this martix raid 0 stuff out.
Thanks!
