Thanks! :)
Hello guys :)
I found some time for make a little update:
http://www.tweakers.fr/download/CPU-Tweaker.rar
Only for reading timings on Sandy and Ivy Bridge for now.
Probably some bugs, let me know
=>donmarkoni: thank for your report.
New update: http://www.tweakers.fr/download/CPU-Tweaker.rar
Also, don't work on LGA2011 for now, and I don't know when I have time to do it.
Felix,
nice to see you back.
Multi error with Sandy....
http://i10.aijaa.com/b/00504/10534748.jpg
Thank guys.
I have some problems with CPU and memory ratio, I try to fix this as soon as I get info.
Hey good to see this is still being developed.
Made a screenie for you:
http://i.imgur.com/mrJgt.jpg
there are some odd things but it mainly look okay.
odd:
- socket
- memsize
- cpu speed
- cmd rate
- dram io lat.
Hope it helps to make it better.
One of the most necessary tools for benching gets an update, awesome!! :up::up::up:
Can you add tRC (Row Cycle Time) and correct the bug with tWR (Write Recovery Time) where it is not settable on some X58 motherboards (ie not settable on R3E, R3BE, Classified3 / Settable on X58A-OC).
Thanks again FELIX. No problems yet running smooth :)
=>DarkjeThe2nd: I send you an MP, but you can try this version: CPU-Tweaker.rar
-Fix Socket and Memory Size reading.
-Fixe Command Rate reading.
-Replace some timings by Round Trip Latency.
=>spoolindsm127: I never found tRC in LGA1366 CPUs datasheet, and is not possible to change tWR under Windows.
Thanks for the reply FELIX.
But with tWR if I remember correctly X58A-OC allowed it to be changed. Donmarkoni runs the same board (or atleast did at one point) so can you confirm?
...Yes, but only by the bios, not under Windows.
socket ok, memory size still at 12g (have 16g)
commandrate matches other readings/settings so is okay
the rtl's value's seem te be off (from memtweakit) 1 tick on the first pair, displaying 44 where mt shows 45, but mt could be wrong there too.
io latency also mismatches mt's readout and it looks like the pairs may be swapped too.
I've read the pm and send you the dumps requested. here's the current result as image: http://i.imgur.com/5zMQQ.jpg
regards, darkje
It has earned it's place in your sig ;)
I distinctly remember you mentioning how you always thought tWR was unsettable in Windows until you ran the X58A-OC. I had sold the one I originally bought, but just picked up another one recently :p:
@FELIX
Is there any way to have CPU-Tweaker start up with windows to load certain settings, but then self exit after doing so? Or is there any way the customized settings can be loaded at start up without the actually app CPU-Tweaker starting? Because I have experienced issues when returning from sleep mode; CPU-Tweaker crashes and memory timings are incorrectly displayed, as if they've been changed or something.
Ok, I did check A and B separately, but both show the same non matching (to mt) value's for I/O and RTL's.
image: http://i.imgur.com/4UdWH.jpg
ed: just spotted cpu-z showing wrong fsb:dram ratio of 1:8, should be 105:1120 = 1:10.66~
okay, thx for clearing that up... :)
Beta 7 fix my 2600K Multi.
Promoted Felix to Legend.
:toast:
well deserved
