Refresh Mode Select -> 15.6 work it's the highest value
Idle Cycle Limit -> 16 or 32 work (i also have 0, 4, 8, 64, 128 or 256 value to set)
Read/Write Queue Bypass -> 16x by default (and is the highest value)
Queue Bypass Max -> 7x by default (and is the highest value)
I remember testing the different Refresh Mode Select and Idle Cycle Limit settings, and 15.6us seemed to work the best. Whether 3.9, 7.8 or 15.6 is the optimal choice is dependent on your memory speed, and you'll just have to test and compare since I don't remember the formula to find that out (sorry). Idle Cycle limit seemed to vary, but 16 or 32 usually worked best. The Queue Bypass options I always lost performance setting them any lower, so they were never changed on my system.
