Hey guys.. I have a question..
Would updating my bios help with OC results?
I have DFI Expert and haven't updated yet.
I would test it out for myself but my OCZ 520 couldn't handle my rig and pooped out. Waiting for my PC Power 1kw to come in. :)
Well I sure as hell think AMD boxed cooer is air...Quote:
Boxed AMD cooler
I shaved retention bracket down for more pressure so I could stop overheating at 1.65v 2.9ghz but now I can't get good contact. damn IHS I hate using them.
There's just not sufficient space to do so given the layout if you're on phase change due to the size of the hold down bracket for the evap :(Quote:
Originally Posted by dinos22
Other bad news... Just got done with my second attempt and it came out nearly worse than attempt 1. This just can't be done with common hand tools. It requires the use of some precision high speed rotary work not to crack the plexi when working so close to the edges. I give up for now, I might try talking with some local shops to see if they can produce a solid one for me as I'm pissed off at this point and willing to pay someone to do it for me, bleh.
What kind of drill bits are u using? There are special plexi/lexan bits u can buy, and they work awesome.
use plexiglass.Quote:
Originally Posted by FragTek
Originally Posted by keichan82
your OCZ Powerstream 520w..pooped out???!!!:eek:
what are you running???
I ran 2.8ghz dual core, 7800gt sli, 2 hdds, 1 optical, a few fans, and 2 ccfls on mine, it smelt likle BBQ before I went dual PSU.
DFI ExpertQuote:
Originally Posted by nealh
Opt 170 OC
2 x 1Gb OCZ Platinum
2 x eVga 7800 GTX
2 x 74gb Raptors Raid 0
2 x WD 400GB 16MB sata2
1 x Seagate 400GB
1 x Seagate 160GB
2 x NEC DVD DL Burner
1 x Floppy
Fan Controller / LCD
Audigy 2
5 x ThermalTake 80mm Smart Fans
1 x ThermalTake 120mm Smart Fan
SI - 120
Aspire Navigator Case
Turn it on.. it goes off.. 3 times and pooped out never to be turned on again..
Read forums and they say even OCZ 600 or PC Power 510 not good enough so... Im going with PC Power 1kw .. so i dont have to worry if I go water :)
I've actually found a place that does custom laser cutting extremely cheap :D I'm CAD'ing up the design right now and going to send it to them for a test run. Once I get that piece if all fits well then booyah, gonna just have em run a whole bunch :)
Originally Posted by cdelatte
I am using water chiller and abogee block. Water temps +6 - + 12 C
not yet tested any colder water. Cpu is max +26 C
I am using 2800/ 1.48v 24/7
Just testing max stable speed and beching . More volts and speed :)
Still in progress for max.
Just got my opty today. W00t. ccbwe 0550UPMW. Will give it a good beating, uh burning in tonight, and will update when the numbers get bigger.
Also, whats a good temp monitoring tool for my infinity board? Smartguardian didnt seem to detect any of the temps right. (jumped from 16 to 22...)
(edit) ntune seems to be working well.
Check out Speedfan, it's a pretty nifty little monitoring program :)Quote:
Originally Posted by Sorrow13
Tcase has a bug in it actually so that all DC opties show up as 49C. X2's also i think...
I think you need some more storage space. :p: Good thing that psu has enough power for a city block :DQuote:
@fragtek, how much are you goin to sell them for?
Originally Posted by Budwise
no , mine show:
Maximum Case Temperature = 53C
TDP: 55.0 Watts
opteron 175 0543 MPMW
what will this CPU overclock to... on air & liquid & phase/chilled water
just ordered a 1 x Opteron Dual Core 165 1.8 Ghz 1Mb Cache 939 CCBWE 0546 FPMW from Tankguys. Supposedly the cab2e single core version of this processor is the bomb. I'm just not happy with my 170. It won't do more than 2.6 no matter what. What version is zipzoomfly shipping right now? will it do at least 2.7? That is my goal.
Guys, any idea on how a 165 CCBWE 0546 FPMW are doing
I'm gettng two 165's tomorrow. I will throw them in and post how they do. I can do air, wc or vapo pe. Which would you like?Quote:
Originally Posted by Red.Sky
how do these do?
I'm on air here so I would definetly like to see what they can do on air. Also, where did you buy them from?Quote:
Originally Posted by dogsx2
lol, just a sec behind me I suppose :)Quote:
Originally Posted by Kaiser_Sose
ZZFly, they are the cheapest. $316 retail shipped 2nd day.Quote:
Cool,Quote:
I'll be looking forward to seeing your results. Hopefully you can post before 3:00 central so I can get them shipped out same day. I really want 2.7!
That's not going to happen. Fedx doesn't come until 4:30 eastern.Quote:
